When I try running create_system_node_nest it crashes Revit. I feel like there is something I’m not getting about the recursion aspect, but I have nothing to go off of other than Revit crashing with no errors.
# Classes
class SystemNode:
def __init__(self, familyName, equipmentName, elecSystems):
self.familyName = familyName
self.equipmentName = equipmentName
self.elecSystems = elecSystems
self.children = []
self.parent = None
def add_child(self, child):
child.parent = self
self.children.append(child)
def get_level(self):
level = 0
p = self.parent
while p:
level += 1
p = p.parent
return level
def print_system(self):
prefix = ".." * self.get_level()
print(prefix + self.equipmentName)
if self.children:
for child in self.children:
child.print_system()
def create_system_node_nest(self):
for e in self.elecSystems:
elem = e.Elements
if elem.Size == 1:
for el in elem:
if el.Symbol.FamilyName in equipmentFam:
equipmentName = el.LookupParameter("Com_MarkInstance").AsString()
familyName = el.Symbol.FamilyName
elecSys = el.MEPModel.GetElectricalSystems()
newNode = SystemNode(familyName, equipmentName, elecSys)
self.add_child(newNode)
if self.children:
child.create_system_node_nest()
# Collect the elements
equipmentCollection = FilteredElementCollector(doc).\
OfCategory(DB.BuiltInCategory.OST_ElectricalEquipment).\
WhereElementIsNotElementType().\
ToElements()
# families to collect
equipmentFam = ["EQ - Panelboard", "EQ - Distribution Panel", "EQ - Transformer Dry Type",
"EQ - Transformer Pad Mounted", "EQ - Automatic Transfer Switch", "EQ - Motor Control Center"]
# Functions
equip = []
def get_system_viable_equipment():
for eC in equipmentCollection:
famName = eC.Symbol.FamilyName
if famName in equipmentFam:
equip.append(eC)
allSystems = []
def create_system_nodes_top():
for e in equip:
# print("____________________Equipment_______________________")
equipmentName = get_equipment_name(e)
supplyFrom = e.LookupParameter("Supply From").AsString()
familyName = e.Symbol.FamilyName
# print("NAME : " + equipmentName)
# print(output.linkify(e.Id, equipmentName))
# print("--- " + e.Symbol.FamilyName)
# print("--- Fed from : " + e.LookupParameter("Supply From").AsString())
# for eS in elecSys:
# print("--- --- Base family is : " + str(eS.BaseEquipment.Symbol.FamilyName))
# print("--- --- Base element name is : " + str(eS.BaseEquipment.LookupParameter("Com_MarkInstance").AsString()))
# elements = eS.Elements
if supplyFrom == "":
# print("--- Top Level")
elecSys = e.MEPModel.GetElectricalSystems()
# create Equipment class element
newTop = SystemNode(familyName, equipmentName, elecSys)
allSystems.append(newTop)
# Run
print(allSystems)
# Crashes Revit. YAY!
for s in allSystems:
s.create_system_node_nest()
s.print_system()
