It seems this weekend was all about the reverse engineering of Adobe’s create suite. this video talks about Revit to a point that I started feeling I need to suggest a new feature for pyRevit, to recreate Revit!
Devloai would eat credits like a cookie monster. If I get the chance, I would probably add RevitAPI access to Stairs, Ramps and Railings.
Honestly, Revit isn’t worth recreating. There is 20 years of old tech that need to be redone from the ground up.
For example… 4D
Yes. Revit has phases, but that isn’t 4D. So much lacking there that it isn’t worth recreating. As an example Families need 4D visibility. Doors for instance can have a swing at 45 or 90 in a view, but it will be the same in all views.It needs to open and close. And then there is just the antiquated way it does an infill when you demo a door or window. That’s been a pita since day one
And what about a feature like Fusion that retains your design history but allows you to graphically shuffle the order of your decisions for a different result. Yes, simpler the cadcam, but something Revit needs.
Likewise the file format and distributed work could be much more robust. It is way too linear right now. For true collaboration you need a way that different team design decisions can be reconciled.
I actually blocked out a modern 4D BIM white paper with AI and it was enlightening Revit is top dog right now, but there is plenty left to do that Revit could be unseated.
Unfortunately this would take a Torvald Linux type. I’d love to be on a team and have pondered open source
BIM for years. Maybe a retirement hobby.
But it would take a real vision and the AI credits wouldn’t be cheap
And let’s face it. Most open source apps are so so. GIMP gets the job done. But I’d rather use Photoshop. There just isn’t a list of killer open source apps. Otherwise Linux would have mopped the floor with Windows on the desktop. So it became the killer network app.
And if adsk isn’t busy building the next gen of BIM, I better sell my stock.
we need 200k, 100k goes no Conda Modeling and another 100k goes to building a Linux based Revit clone, open source with installation size not to exceed 300mb. flat learning curve. zero telemetry and zero BS. I will remove the Site & energy Tabs, and Generate a new file format. .rvx
Alternatively, we can have it as a BIM skin on top of Rhino, so we can run “Revit.Inside Rhino”!
I thought about this idea of skin thinking about blender. Everything is there for bim in terms of infra, the dedicated UX is lacking love mostly / bonsaï
A new .rvx format would add a lot of integration burden before there is any ecosystem around it. Since the CONDA viewer already handles IFC, E57, STEP, mesh and JSON, I’d make the viewer format-agnostic first: reliable import, round-trip checks and a clean API matter more than owning a file format. Modeling can come later on top of that, whether standalone or as a skin on Rhino/Blender.
