hi all,
i’m trying to make a script to calculated the room heights in a linked model using raybounce technique.
The raytracing seems to work but something is off with how the points are being recalculated to internal units and back so that it gives completly wrong info.
i’m using a simple generic block family to indicate the calculation points:
before the units convertion and after
here is my Code where i’m at:
sys.path.append(r'H:\\_GROEPEN\\CAD\\DEV\\Tools\\CMRP')
from pyrevit import UI
from pyrevit import revit
from Autodesk.Revit.DB.Structure import StructuralType
from CMRPGUI import *
from CMRP import *
# Doc & App
uidoc = revit.uidoc
links = link_selection(doc)
room_points = []
room_Id = []
for link in links:
link = link.GetLinkDocument()
rooms = FilteredElementCollector(link).OfCategory(BuiltInCategory.OST_Rooms).ToElements()
# Get rooms information from linked model
for room in rooms:
if isinstance(room.Location, LocationPoint):
room_points.append(room.Location.Point)
room_Id.append(room.UniqueId)
def get_type_by_name(type_name):
param_type = ElementId(BuiltInParameter.ALL_MODEL_TYPE_NAME)
f_param = ParameterValueProvider(param_type)
evaluator = FilterStringEquals()
f_rule = FilterStringRule(f_param, evaluator, type_name, True)
filter_type_name = ElementParameterFilter(f_rule)
return FilteredElementCollector(doc).WherePasses(filter_type_name).WhereElementIsElementType().FirstElement()
with Transaction(doc, "Place Generic Model Instances") as t:
symbol = get_type_by_name('test-Type1')
if not symbol.IsActive:
symbol.Activate()
for p in room_points:
doc.Create.NewFamilyInstance(p, symbol, StructuralType.NonStructural)
views = FilteredElementCollector(doc).OfClass(View).WhereElementIsNotElementType().ToElements()
for x in views:
if x.Name == "ray3D":
view = x
break
#Document UI Units
UIunit = Document.GetUnits(doc).GetFormatOptions(UnitType.UT_Length).DisplayUnits
UIunit = Document.GetUnits(doc).GetFormatOptions(SpecTypeId.Length).GetUnitTypeId()
# translation_vector = XYZ(0, 0, 1000)
# # Translate each point in room_points so that it is above the floor
# for i in room_points:
# i = i.Add(translation_vector)
# #Inputs : Points, Direction, 3D View
if isinstance(room_points,list):
points = [XYZ(UnitUtils.ConvertToInternalUnits(i.X,UIunit),UnitUtils.ConvertToInternalUnits(i.Y,UIunit),UnitUtils.ConvertToInternalUnits(i.Z,UIunit)) for i in room_points]
points = [XYZ(UnitUtils.ConvertToInternalUnits(room_points.X,UIunit),UnitUtils.ConvertToInternalUnits(room_points.Y,UIunit),UnitUtils.ConvertToInternalUnits(room_points.Z,UIunit))]
direction = XYZ(0,0,1)
ex = []
pts = []
elems = []
ri = ReferenceIntersector(view)
ri.FindReferencesInRevitLinks = True
# # Find nearest reference for each point and compute height
heights = []
for p in points:
# Place a family instance at the original point
instance1 = doc.Create.NewFamilyInstance(p, symbol, StructuralType.NonStructural)
ref = ri.FindNearest(p, direction)
if ref is not None:
refel = ref.GetReference()
link_instance = doc.GetElement(refel.ElementId)
elem = link_instance.GetLinkDocument().GetElement(refel.LinkedElementId)
print(elem.Id)
refp = ref.GetReference().GlobalPoint
# Place a family instance at the detected reference point
instance2 = doc.Create.NewFamilyInstance(refp, symbol, StructuralType.NonStructural)
height = UnitUtils.ConvertFromInternalUnits(refp.Z, UIunit) - UnitUtils.ConvertFromInternalUnits(p.Z, UIunit)
heights.append(height)
print("Element: {}, Height: {}".format(elem.Name, height))
heights.append(None)
print("No reference found")
print(heights)
