I’m making some plugin shortcuts in a custom window in Revit (MyTools), and due to the large amount of plugins I would like to hide the unnecessary plugin bars, but I noticed that when using the MinifyUI command, the hidden plugin commands are no longer executed .
as an example of a shortcut: CropView
-- encoding: utf-8 --
title = “”“Crop
View”“”
helpurl = “”
doc = “”“Shortcut”“”
from pyrevit import HOST_APP, UI
uiapp = HOST_APP.uiapp
uiapp.PostCommand(UI.RevitCommandId.LookupCommandId(“CustomCtrl_%CustomCtrl_%Alpha BIM%General Add-ins%CropViewCmd”))
when I turn off MinifyUI it goes back to working the shortcut / plugin icon / shortcut of the pyrevit toolbar.
- is there any way to make MinifyUI not “delete” the plugin temporarily?
here is the PYREVIT shortcut working (without activating the MinifyUI)
’ [Jrn.Tooltip] Rvt.Attr.Tooltip.CommandID: CustomCtrl_%CustomCtrl_%MyTools%Plugins%pl_icon2 Rvt.Attr.Tooltip.ElapsedTime: 0,9545151 Rvt.Attr.Tooltip.Enabled: True Rvt.Attr.Tooltip.IsFirst: True Rvt.Attr.Tooltip.Key: CustomCtrl_%CustomCtrl_%MyTools%Plugins%pl_icon2 Rvt.Attr.Tooltip.Progressive: True Rvt.Attr.Tooltip.Progressive.Delay: 2
'E 24-Jun-2023 11:42:04.915;   0:<
Jrn.RibbonEvent “Execute external command:CustomCtrl_%CustomCtrl_%MyTools%Plugins%pl_icon2:mytool-mytools-plugins-plundersicon2”
’ 1:< ::89:: Delta VM: Avail 134143895 MB, Used +17 → 1397 MB; RAM: Avail -17 → 19390 MB, Used +17 → 1502 MB, Peak +15 → 1502 MB
’ 1:< GUI Resource Usage GDI: Avail 8563, Used 1437, User: Used 579
’ 1:< Muted: Jrn.Directive IdleTimeTaskSymbol
’  1.042260   1:<<<API External Command Time
'H 24-Jun-2023 11:42:05.981;   0:<
Jrn.Data  _
“APIStringStringMapJournalData”  , 0
'E 24-Jun-2023 11:42:06.034;   0:<
Jrn.MouseMove    0 ,    328 ,    369
'H 24-Jun-2023 11:42:06.034;   0:<
Jrn.Directive  _
“IdleTimeTaskInvocation”  , “2.PostCommandTask” , 0 _
'E 24-Jun-2023 11:42:06.042;   0:<
Jrn.RibbonEvent “Execute external command:CustomCtrl_%CustomCtrl_%Alpha BIM%General Add-ins%CropViewCmd:AlphaBIM.CropViewCmd”
’ 1:< API_ERROR { : Assembly version conflict in some references in CropView.dll assembly
'Addin’s module RevitAPIUI of version 19.0.0.0 conflicts with same preloaded module of version 24.0.0.0
'Addin’s module RevitAPI of version 19.0.0.0 conflicts with same preloaded module of version 24.0.0.0
'Addin’s module Newtonsoft.Json of version 9.0.0.0 conflicts with same preloaded module of version 13.0.0.0
'Addin’s module ControlzEx of version 4.0.0.0 conflicts with same preloaded module of version 3.0.2.4
'Addin’s module RevitAPIIFC of version 19.0.0.0 conflicts with same preloaded module of version 24.0.0.0 }
’ 1:< ::91:: Delta VM: Avail -18 → 134143877 MB, Used +6 → 1403 MB, Peak +5 → 1404 MB; RAM: Avail -12 → 19379 MB, Used +7 → 1509 MB, Peak +7 → 1509 MB
’ 1:< GUI Resource Usage GDI: Avail 8574, Used 1426, User: Used 572
here is the non working PYREVIT shortcut (active MinifyUI)
’ [Jrn.Tooltip] Rvt.Attr.Tooltip.CommandID: CustomCtrl_%CustomCtrl_%pyRevit%Toggles%MinifyUI Rvt.Attr.Tooltip.ElapsedTime: 1,9631725 Rvt.Attr.Tooltip.Enabled: True Rvt.Attr.Tooltip.IsFirst: True Rvt.Attr.Tooltip.Key: CustomCtrl_%CustomCtrl_%pyRevit%Toggles%MinifyUI Rvt.Attr.Tooltip.Progressive: True Rvt.Attr.Tooltip.Progressive.Delay: 2
'E 24-Jun-2023 11:42:16.211;   0:<
Jrn.RibbonEvent “Execute external command:CustomCtrl_%CustomCtrl_%pyRevit%Toggles%MinifyUI:pyrevittools-pyrevit-toggles-toggles1-minifyui”
’ 0:< ::106:: Delta VM: Avail +1 → 134143883 MB, Used +27 → 1410 MB; RAM: Avail -26 → 19352 MB, Used +27 → 1543 MB, Peak +38 → 1561 MB
’ 0:< GUI Resource Usage GDI: Avail 8562, Used 1438, User: Used 577
’  2.751060   1:<<<API External Command Time
'H 24-Jun-2023 11:42:18.965;   0:<
Jrn.Data  _
’ 0:< ::106:: Delta VM: Avail +7 → 134143891 MB, Used +1 → 1411 MB; RAM: Avail +11 → 19364 MB, Used +1 → 1544 MB
’ 0:< GUI Resource Usage GDI: Avail 8564, Used 1436, User: Used 576
'E 24-Jun-2023 11:42:21.978;   0:<
Jrn.MouseMove    0 ,    721 ,      1
'E 24-Jun-2023 11:42:21.979;   0:<
’ 1:< ::108:: Delta VM: Avail 134143891 MB, Used +18 → 1429 MB; RAM: Avail -16 → 19348 MB, Used +18 → 1562 MB, Peak +1 → 1562 MB
’ 1:< GUI Resource Usage GDI: Avail 8564, Used 1436, User: Used 576
’  1.117191   1:<<<API External Command Time
'H 24-Jun-2023 11:42:23.097;   0:<
Jrn.Data  _
’ 0:< ::108:: Delta VM: Avail -8 → 134143883 MB, Used +0 → 1430 MB; RAM: Avail +10 → 19358 MB, Used +0 → 1563 MB, Peak +0 → 1563 MB
’ 0:< GUI Resource Usage GDI: Avail 8564, Used 1436, User: Used 579
'E 24-Jun-2023 11:42:23.201;   0:<
Jrn.MouseMove    0 ,    584 ,    454
'H 24-Jun-2023 11:42:23.202;   0:<
Jrn.Directive  _
“IdleTimeTaskInvocation”  , “3.PostCommandTask” , 1 _
’ 0:< API_SUCCESS { API queue command CustomCtrl_%CustomCtrl_%Alpha BIM%General Add-ins%CropViewCmd cannot be invoked in this context. }
'H 24-Jun-2023 11:42:23.204;   0:<
Jrn.Directive  _
, “end”
