EddieS
                    January 30, 2024,  2:04am
                  1
              Is possible to control the contents of one Combobox from another.
Eg.
Hope this makes sense
                Jean-Marc
                    January 30, 2024,  7:28am
                  2
              Check out the colour splasher code. It is a bit convoluted but works that way for this script.
To keep it simpler, you could display the combo boxes in sequence as a first step
                dosymep
                    January 30, 2024, 12:17pm
                  3
              Create OptionValue class
class OptionValue:
    def __init__(self, name):
        self._name = name
    @property
    def name(self):
        return self._name
    @name.setter
    def name(self, value):
        self._name = value
Create Option class
class Option:
        self._name = name
        self._values = []
    @property
    def name(self):
        return self._name
    @name.setter
        self._name = value
    @property
    def values(self):
        return self._values
    @option_values.setter
    def values(self, value):
        self._values = value
Create xaml file
<StackPanel>
    <ComboBox
        Width="150"
        SelectedItem="{Binding Option}"
        ItemsSource="{Binding Options}">
        <ComboBox.ItemTemplate>
            <DataTemplate>
                <TextBlock Text="{Binding name}" />
            </DataTemplate>
        </ComboBox.ItemTemplate>
    </ComboBox>
    <ComboBox
        Width="150"
        ItemsSource="{Binding Option.values}">
            <DataTemplate>
            </DataTemplate>
    </ComboBox>
</StackPanel>
                EddieS
                    January 30, 2024,  9:52pm
                  4
              I will look into it
Appreciate you assistance.
                EddieS
                    February 16, 2024,  3:27am
                  5
              Been trying to understand how to incorporate this into my code… not having much luck unfortunately.
                dosymep
                    February 21, 2024,  2:16pm
                  6
              @EddieS , my button with bindings and MVVM
              def Execute(self, parameter):
                  self.__view.Hide()
                      self.__view_model.curve_element = self.__revit_repository.pick_element("Выберите линию.")
                  finally:
                      self.__view.show_dialog()
          @notification()
          @log_plugin(EXEC_PARAMS.command_name)
          def script_execute(plugin_logger):
              revit_repository = RevitRepository(document, __revit__)
              if revit_repository.is_empty:
                  alert("Выберите помещения для нумерации", exitscript=True)
              select_groups_window = SelectRoomGroupsWindow(revit_repository.room_groups)
              select_groups_window.show_dialog()
              if not revit_repository.get_filtered_rooms_by_group() or not select_groups_window.DialogResult:
                  script.exit()
              main_window = MainWindow()
