PyRevitLoader - Token System Error
I’ve been using pyRevit for 2025 and 2026 for a while now but started getting an IronPython Traceback error with something in regard to tokens, see screenshot below:
I’ve found an almost similar error traceback forum post, but no mention of tokens in the error code such as this post. There is this bug report on Github, not quite sure if it’s the same as mine. With this error, a couple of the pyRevit tools do not work such as tab coloring, for example.
Other information that might be useful:
.NET Framework version: 4.8.09221
PyRevit v6.4.0
IronPython 2.7.12
Revit 2026.4.1
I can provide additional information as needed and any aid would be greatly appreciated.
Both links are unrelated.
The error relates to tab coloring
Did you try to specify colors manually? Or something similar?
Yes, I had updated colors and tab fill in the UI/UX area. I haven’t been able to access the Settings even after uninstalling/reinstalling pyRevit since this error popup. See below for error code when trying to access settings:
 File "C:\Users\UserMachineName\AppData\Roaming\pyRevit-Master\extensions\pyRevitCore.extension\pyRevit.tab\pyRevit.panel\Settings.smartbutton\script.py", line 1036, in <module>
 File "C:\Users\UserMachineName\AppData\Roaming\pyRevit-Master\extensions\pyRevitCore.extension\pyRevit.tab\pyRevit.panel\Settings.smartbutton\script.py", line 121, in __init__
 File "C:\Users\UserMachineName\AppData\Roaming\pyRevit-Master\extensions\pyRevitCore.extension\pyRevit.tab\pyRevit.panel\Settings.smartbutton\script.py", line 257, in _setup_uiux
 File "C:\Users\UserMachineName\AppData\Roaming\pyRevit-Master\pyrevitlib\pyrevit\revit\tabs.py", line 108, in get_tabcoloring_theme
 File "C:\Users\UserMachineName\AppData\Roaming\pyRevit-Master\pyrevitlib\pyrevit\revit\tabs.py", line 49, in _get_tab_orderrules
 File "C:\Users\UserMachineName\AppData\Roaming\pyRevit-Master\pyrevitlib\pyrevit\revit\tabs.py", line 13, in hex_to_brush
SystemError: Token is not valid.
System.FormatException: Token is not valid.
 at MS.Internal.Parsers.ParseColor(String color, IFormatProvider formatProvider, ITypeDescriptorContext context)
 at System.Windows.Media.ColorConverter.ConvertFromString(String value)
 at Microsoft.Scripting.Interpreter.FuncCallInstruction`2.Run(InterpretedFrame frame)
 at System.Dynamic.UpdateDelegates.UpdateAndExecute3[T0,T1,T2,TRet](CallSite site, T0 arg0, T1 arg1, T2 arg2)
 at IronPython.Compiler.Ast.CallExpression.Invoke1Instruction.Run(InterpretedFrame frame)
 at Microsoft.Scripting.Interpreter.LightLambda.Run3[T0,T1,T2,TRet](T0 arg0, T1 arg1, T2 arg2)
 at Microsoft.Scripting.Interpreter.DynamicInstruction`4.Run(InterpretedFrame frame)
 at IronPython.Runtime.Method.MethodBinding.SelfTarget(CallSite site, CodeContext context, Object target)
 at System.Dynamic.UpdateDelegates.UpdateAndExecute2[T0,T1,TRet](CallSite site, T0 arg0, T1 arg1)
 at Microsoft.Scripting.Interpreter.DynamicInstruction`3.Run(InterpretedFrame frame)
 at System.Dynamic.UpdateDelegates.UpdateAndExecute4[T0,T1,T2,T3,TRet](CallSite site, T0 arg0, T1 arg1, T2 arg2, T3 arg3)
 at IronPython.Runtime.Types.LateBoundInitBinder.FastInitSite`1.CallTarget(CallSite site, CodeContext context, Object inst, T0 arg0)
 at IronPython.Runtime.Types.PythonType.FastTypeSite`1.CallTarget(CallSite site, CodeContext context, Object type, T0 arg0)
 at IronPython.Compiler.PythonScriptCode.Run(Scope scope)
 at Microsoft.Scripting.Hosting.CompiledCode.Execute(ScriptScope scope)
Try removing related lines about tabs coloring in the pyrevit-config.ini file
Deleting the couple lines under [tabcoloring] in the pyRevit_config.ini file did fix my error! I’m able to access the settings again but I don’t know if this will occur again.
Please try editing the colors from the UI and report. If it is an issue, file in an issue report on GitHub
I have been able to edit UI/UX colors, and the color profiles were saved from R2026 and worked in R2025 too. I will issue a bug report on GitHub if the issue re-occurs in the future.
