In Revit I use pyrevit, in which I create my own tab. Since I have pyrevit installed, unfortunately no node in CPython3 works. If I uninstall pyrevit everything works as it should. All nodes in CPython3 reports the same error (see picture). Does anyone know how to solve the problem please?
A lot of users have this issue and Dynamo Team is aware of it, i don´t know when they will solve it.
I have the duct tape solution, just create a new line in the script, then it works…
you can bridge the gap with loading IronPython2 and 3 package to dynamo.
Does anyone know if there is any progress on this topic? We have many scripts we are currently using in pyrevit, and it is not a solution for me to go through all of them and change every Python node. Nevertheless I also ran into a situation when the solution drom Andreas didnt work.
