"pyrevit run" can't open model with non ASCII symbol in path
I have a problem where when I try to open a model and run some scripts on it, everything works fine as long as the path to the model does not contain non ASCII character.
For example:
Following command work fine:
pyrevit run “Q:\Jaroslav_Ruzicka\Kontrola_Modelu_Python\OpenRevit.py” “Q:\Jaroslav_Ruzicka\Kontrola_Modelu_Python\1516_DSP_Kuchyne CP_detached.rvt” --revit=2024
But this command won’t open specified model:
pyrevit run “Q:\Jaroslav_Ruzicka\Kontrola_Modelu_Python\OpenRevit.py” “Q:\Jaroslav_Ruzicka\Kontrola_Modelu_Python\1516_DSP_Kuchyně CP_detached.rvt” --revit=2024
and will resolve in following error message:
==> Execution Environment
Execution Id: “ff733e90-0c87-4675-a29d-142398a25dda”
Product: 24.2.1 | Version: 24.2.10.64 | Build: 20240408_1515(x64) | Language: 1033 | Path: "C:\Program Files\Autodesk\Revit 2024"
Clone: master | Deploy: “basepublic” | Branch: “master” | Version: “4.8.16.24121+2117” | Path: “C:\Program Files\pyRevit-Master”
Engine: DEFAULT | Kernel: IronPython | Version: 2711 | Runtime: True | Path: “C:\Program Files\pyRevit-Master\bin\engines\IPY2711PR\pyRevitLoader.dll” | Desc: “Custom pyRevit IronPython Engine”
Script: “Q:\Jaroslav_Ruzicka\Kontrola_Modelu_Python\OpenRevit.py”
Working Directory: “C:\Users\ruzicka\AppData\Local\Temp\ff733e90-0c87-4675-a29d-142398a25dda”
Journal File: “C:\Users\ruzicka\AppData\Local\Temp\ff733e90-0c87-4675-a29d-142398a25dda\PyRevitRunner_ff733e90-0c87-4675-a29d-142398a25dda.txt”
Manifest File: “C:\Users\ruzicka\AppData\Local\Temp\ff733e90-0c87-4675-a29d-142398a25dda\PyRevitRunner.addin”
Log File: “C:\Users\ruzicka\AppData\Local\Temp\ff733e90-0c87-4675-a29d-142398a25dda\PyRevitRunner_ff733e90-0c87-4675-a29d-142398a25dda.log”
==> Target Models
==> Execution Log
File “Q:\Jaroslav_Ruzicka\Kontrola_Modelu_Python\OpenRevit.py”, line 23, in
Exception: The document to be opened does not exist.
Autodesk.Revit.Exceptions.FileNotFoundException: The document to be opened does not exist.
at Autodesk.Revit.UI.UIApplication.OpenAndActivateDocument(String fileName)
at Microsoft.Scripting.Interpreter.FuncCallInstruction3.Run(InterpretedFrame frame) at Microsoft.Scripting.Interpreter.Interpreter.Run(InterpretedFrame frame) at Microsoft.Scripting.Interpreter.LightLambda.Run4[T0,T1,T2,T3,TRet](T0 arg0, T1 arg1, T2 arg2, T3 arg3) at System.Dynamic.UpdateDelegates.UpdateAndExecute3[T0,T1,T2,TRet](CallSite site, T0 arg0, T1 arg1, T2 arg2) at Microsoft.Scripting.Interpreter.DynamicInstruction4.Run(InterpretedFrame frame)
at Microsoft.Scripting.Hosting.ScriptSource.Execute(ScriptScope scope)
at PyRevitLoader.ScriptExecutor.ExecuteScript(String sourcePath, IEnumerable1 sysPaths, String logFilePath, IDictionary2 variables)
Difference between those 2 commands is letter ě in revit file name. But the error pops out even when one of the files contains similar letters.
Is there a way around this?
It seems unfeesable to change the entire folder structure in our company to ASCII characters.
Thank you
Ahoj,
What is your code in OpenRevit.py? (at least up to line 23)
I have bunch of coments in the file above my code, but this is what executes:
from pyrevit import revit, DB, forms, HOST_APP
import RevitTests
uidoc = HOST_APP.uiapp.OpenAndActivateDocument(models[0])
doc = uidoc.Document
RevitTests.runTests(doc)
Line 23 is this:
The RevitTests.runTests(doc) runs several tests on the file like the one below, And when the path contains only ASCII arrors it does not produce any errors.:
def getRevitLinkCount(documentHandle):
collector = FilteredElementCollector(documentHandle)
linkedModels = collector.OfClass(RevitLinkType)
counter = linkedModels.GetElementCount()
return counter
Just an update. I did managed to fix the issue using a workaround.
I don’t think the problem was with the pyrevit itself but rather with the Revit API.
Pyrevit will launch Revit and it will launch the script on a selected model.
And then Revit API itself will throw this exception:
Because it for some reason can’t work with path that has non ASCII character like “ě”.
The way I got around this is, I converted the path to a Revit model into 8.3 adress format using this function.
def get_short_path(long_path):
buffer_size = 512
buffer = ctypes.create_unicode_buffer(buffer_size)
if ctypes.windll.kernel32.GetShortPathNameW(long_path, buffer, buffer_size):
    return buffer.value
    return None
When launching my pyrevit script I convert all my file paths using the function above.
Then script launches normally, even if path to the file contains symbols like these: RBá+ěščéřížýáůú.rvt
thanks for that!
Not everybody comes back and provide the feedback/answer
