Are there plans for better integration between PyRevit & Rhino Inside?
It would be great to be able to use Rhinoscriptsyntax and Rhino common straight from PyRevit
It already is recognised - check this sample that is part of the pyrevit dev tab
from pyrevit import clr, revit, DB
from pyrevit.framework import Enumerable
clr.AddReference('RhinoCommon')
clr.AddReference('RhinoInside.Revit')
from Rhino import Geometry
from RhinoInside.Revit import Revit, Convert
logger = script.get_logger()
output = script.get_output()
with revit.Transaction("Rhino.Inside Sample7"):
sphere = Geometry.Sphere(Geometry.Point3d.Origin, 12 * Revit.ModelUnits)
brep = sphere.ToBrep()
meshes = \
Geometry.Mesh.CreateFromBrep(brep, Geometry.MeshingParameters.Default)
category = DB.ElementId(DB.BuiltInCategory.OST_GenericModel)
ds = DB.DirectShape.CreateElement(revit.doc, category)
solids = []
for mesh in meshes:
solid = Convert.Geometry.GeometryEncoder.ToSolid(mesh)
solids.append(solid)
for geometry in solids:
ds.AppendShape([geometry])
