PyRevit Keynote Manager
We are having trouble using the PyRevit keynote manager on Forma hosted projects. Its fine to add keynotes to the txt file, but getting Revit to see those updates is another story. For instance I can add a keynote in keynote manager but when I go to place a user keynote in Revit its not available. Its not clear what is necessary to update Revit. ‘Refresh’ does not, ‘Update model’ does not, syncing does not. The only thing that works is going to Keynoting settings and hitting ‘reload’. I just wonder, does hosting the model on Forma work better? I’ll give that a shot next.
Which pyRevvit version?
Our office is a bit behind on pyRevit version…
But - anything outside Revit is not directly accessing Forma. That’s includes images, cad files, pdf and the keynote file. All of those rely not on Forma - butt Autodesk Desktop Connector.
And that is just a file sync thing - so you can see how that can run into timing issues.
I think latest versions of pyRevit have better support for cloud based keynote files.
Hello @skyeg3
Please Tell me which Revit version / PyRevit and Desktop Connector version.
I have pyRevit 7, Revit 2026 and ADC 2027 and I have no issues with it.
If you work of a forma project, it is advisable to save it next to your project since the keynote manager uses pyrevit’s adc library which should be working fine.
