in about 15min you should be able to test the installers and pyrevit in the 2027 preview release (if you are part of the preview, obviously: in browser preview release)
Pyrevit installers here:
Todo
In 24, 25 or 26 and obviously 27
- test CLI commands
- pyrevit run … on models
- pyrevit clone (s) …
- pyrevit extend…
- pyrevit attach…
- all pyrevit devtools extensions command (note: some are broken already, hence the testing in other Revit versions.)
- All devhooks
- All pyrevit core tools
- Add and remove extensions from settings(local, remote ones (gh))
- Check translations switch
- All settings (except maybe telemetry unless you want to go down the rabbit hole)
- Interactions with other addins (dynamo, ideate, diroots, …)
