Hi everybody
I’m facing with an error: everyone in my company, except me that I’ve created the custom tools, has the same problem whe they use some tools where I used “SelectFromList” form:
It seems that I need to indicate 3 arguments, but on my pyrevit Environment the form runs correctly with only 2.
wbslist = [“WBS_L1”,“WBS_L2”, “WBS_L3”,“WBS_L4”,“WBS_L5”]
yn = [“Yes”,“No”]
WBSSelect = SelectFromList('Select wbs parameter to collect level values: ', wbslist)
yesno = SelectFromList(‘Do you want the report?’, yn)
t = Transaction(doc, “Compile WBS parameter for levels”)
I’ve checked if there is a problem with PyRevit version, overwriting also the file of forms in AppData/Roaming…
But it doesn’t work.
Anyone could help me, please?
Thanks in advance
