Could you help me with some code? It should work, but unfortunately not
I run command:
pyrevit run "C:\Users\tomasz.puchala\OneDrive - Arup\pyRevitCLI\myscript.py"
"C:\Users\tomasz.puchala\OneDrive - Arup\pyRevitCLI\WA050-ARP-ZZ-ZZ-M3-A-ZZZZ-9001_test.rvt"
script is straight forward - revit 2021+
from pyrevit import HOST_APP
from Autodesk.Revit.DB import SaveAsOptions
import System
from System import Guid
# __models__ is set to a list of model file paths
for model in __models__:
uidoc = HOST_APP.uiapp.OpenAndActivateDocument(model)
doc = uidoc.Document
filepath = doc.PathName
name = System.IO.Path.GetFileName( filepath )
opt = SaveAsOptions(OverwriteExistingFile = True)
doc.SaveAs(filepath, opt)
accountId = Guid('16254c15-5884-4102-9b1a-XXXX')
projectId = Guid('0ef11c59-0592-475b-b928-XXXX')
folderId = 'urn:adsk.wipprod:fs.folder:co.Y3EPE_zBTFmDu8tLK1XXXX'
doc.SaveAsCloudModel(accountId, projectId, folderId, name)
Error:
File "C:\Users\tomasz.puchala\OneDrive - Arup\pyRevitCLI\myscript.py", line 38, in <module>
Exception: The given Id is not a valid GUID value.
Parameter name: accountId or projectId
Autodesk.Revit.Exceptions.ArgumentException: The given Id is not a valid GUID value.
at Autodesk.Revit.DB.Document.SaveAsCloudModel(Guid accountId, Guid projectId, String folderId, String modelName)
at Microsoft.Scripting.Interpreter.ActionCallInstruction`5.Run(InterpretedFrame frame)
at Microsoft.Scripting.Interpreter.LightLambda.Run7[T0,T1,T2,T3,T4,T5,T6,TRet](T0 arg0, T1 arg1, T2 arg2, T3 arg3, T4 arg4, T5 arg5, T6 arg6)
at System.Dynamic.UpdateDelegates.UpdateAndExecute6[T0,T1,T2,T3,T4,T5,TRet](CallSite site, T0 arg0, T1 arg1, T2 arg2, T3 arg3, T4 arg4, T5 arg5)
at Microsoft.Scripting.Interpreter.DynamicInstruction`7.Run(InterpretedFrame frame)
at Microsoft.Scripting.Hosting.ScriptSource.Execute(ScriptScope scope)
at PyRevitLoader.ScriptExecutor.ExecuteScript(String sourcePath, IEnumerable`1 sysPaths, String logFilePath, IDictionary`2 variables)
I’ve already tested this code in Dynamo (using Rhythm package to get document) and it works as expected (GUIDs are valid).
Am I missing something?
