I have multiple users having issues with pyRevit, which is causing Revit not to open; our company is setup where the users open Revit through their VHD. The users are forced to use the cloud version, however, once pyRevit is disabled, Revit appears to open as expected. If anyone has any insights or speculations as to why this is occurring, I would very much appreciate it.
try a pyrevit env command.
I amm guessing pyrevit is not handling virtual hard drive location for revit properly, if my acronym guess is right.
by running this command, you should see the list of your revit installs. If not, you could open an issue on pyrevit github.
Thanks for getting back. I will try that.
