Hi for professionals!
I’m having issue with processing creating of NewFamilyInstance with pyRevit automation.
Pipeline:
- run code that loads initialization file in Revit via pyrevit terminal RUN command (with 2 files)
- the Revit opens IFC model on backend (you can’t see a viewport)
- it mapps objects and loads families Symbols to revit according the object names
- Activates Families Sylbols
- Should create a new family instance from this symbols ( seems no problem is here)
- saves revit file, exports dwg , and closes Revit.
If I run same code in revit python shell while revit is opened with some initialization model it’s works,
But as long as I try to run same actions by using pyrevit it’s not works - I get in output revit model with loaded families but without instances.
I’ll appreciate any help, Thanks!
