๐ฝ๐๐ฅ๐ฒ๐๐ถ๐ ๐ณ.๐ฌ ๐ถ๐ ๐ผ๐๐. and yes, it is massive again
I strongly suggest you go through the release notes, this really is a massive one with a lots of new stuffs and some breaking changes
๐ง๐๐ผ ๐ณ๐ฒ๐ฎ๐๐๐ฟ๐ฒ๐ ๐๐ต๐ฎ๐ ๐ฐ๐ต๐ฎ๐ป๐ด๐ฒ ๐ต๐ผ๐ ๐๐ผ๐ ๐ฎ๐ฐ๐๐๐ฎ๐น๐น๐ ๐๐ผ๐ฟ๐ธ ๐ถ๐ป ๐ฅ๐ฒ๐๐ถ๐.
๐ญ. ๐๐ป ๐ฎ๐ด๐ฒ๐ป๐ ๐ฟ๐๐ป๐๐ถ๐บ๐ฒ: ๐ผ๐ฝ๐ ๐ถ๐ป, ๐ฏ๐ฟ๐ถ๐ป๐ด ๐๐ผ๐๐ฟ ๐ผ๐๐ป ๐๐.
Claude Code, Codex, Cursor, VS Code, OpenCode. They read and change your live model over MCP. Not 200 stub tools: the agent writes Python, and the Revit API is the toolset.
The human stays in control. Every model change is approved inside Revit, with the touched elements selected and temporarily isolated. Keep commits it as one undo entry. Discard rolls it back.
๐ฎ. ๐ ๐ฟ๐ฒ๐ฎ๐น ๐ฃ๐๐๐ต๐ผ๐ป ๐๐ต๐ฒ๐น๐น ๐ถ๐ป ๐๐ต๐ฒ ๐ฟ๐ถ๐ฏ๐ฏ๐ผ๐ป.
IronPython REPL: modal, modeless, or dockable next to your model. Plus a syntax-highlighted editor with F5 to run. It follows your Revit theme instead of being a grey box.
๐ง๐ต๐ฒ ๐ป๐๐บ๐ฏ๐ฒ๐ฟ ๐๐ผ๐โ๐น๐น ๐ฎ๐ฐ๐๐๐ฎ๐น๐น๐ ๐ณ๐ฒ๐ฒ๐น:
๐ณ.๐ฎร ๐ณ๐ฎ๐๐๐ฒ๐ฟ ๐ฟ๐ฒ๐น๐ผ๐ฎ๐ฑ๐: ๐ฎ๐ฏ.๐ญ ๐ โ ๐ฏ.๐ฎ ๐
Cause: 6.5 spun up a fresh IronPython engine for every extension startup script, about 4 s each. 7.0 shares one.
Also in this release: dark mode across the WPF surface, a WebView2 output renderer _ yes you can use proper iframes and all the latest CSS and JS in the output window now _ , extension credentials sealed with Windows DPAPI, and a CI job that test-signs builds and launches Revit to prove they actually load.
๐ฅ๐ฒ๐๐ถ๐ ๐ฏ๐ฒ๐น๐ผ๐ ๐ฎ๐ฌ๐ฎ๐ญ ๐ถ๐ ๐ป๐ผ ๐น๐ผ๐ป๐ด๐ฒ๐ฟ ๐๐๐ฝ๐ฝ๐ผ๐ฟ๐๐ฒ๐ฑ.
๐๐ป๐น๐ถ๐ป๐ฒ ๐ฏ๐๐ป๐ฑ๐น๐ฒ ๐บ๐ฒ๐๐ฎ๐ฑ๐ฎ๐๐ฎ ๐๐๐ถ๐น๐น ๐๐ผ๐ฟ๐ธ๐, and is committed through at least v8. You donโt have to rewrite a single extension.
Watch the agent runtime in action:
Get it:
This version owes a lot to Christopher Crosley Roman Golev Paul Rubenbauer Andrea Ghensi Tay Othman, AIA ![]()
Built by 18 people and 4 bots.
and is it also easier to support us
