PyPiPie Full Feature Revit Excel Linker
Hot off the press…
Links Excel sheets to either drafting or legend views at 1:1 scale for high visual fidelity with all Excel formatting. Test workbook included. Capable of importing entire workbooks. Easy opening in Excel. Just have the view open and Open. Should work with Autodesk Cloud and Autodesk Desktop Connector.
This is excellent work!! I’ve been meaning to do something similar because dealing with Special Inspection tables manually is a HUGE pain and this just simplified that process so so much.
Just out of curiosity (because it’s a similar tool I’ve been meaning to look more into), but have you considered making a reverse tool? So a dummy table (ie textnotes and detail lines) that’s already in Revit and create an Excel file from that?
Yes - we have an inhouse app that is similar to that. I hate it. It uses a schedule for a generic model family and creates the ENTIRE schedule from the header information. A real kludge in my opinion and I refuse to participate. As someone once said… Fake. Fake. Fake.
I’ll probably add a bidirectional support for this app later. And that isn’t difficult. You can store whole Excel tables inside Revit using Extended Data Storage. But it isn’t a priority (for me). I just want pretty tables that look the same as Excel. Revit is Revit. Excel is Excel.
Higher on my list is a bidirectional Revit <> External Data Source. I want be able to use multiple data sources Excel, Notepad, JSON, etc… We have a lot of Sr. Eng types that don’t get into Revit but want to update info. They use Excel and Ideate BIMLink, but we are trying to get away from Ideate.
