Hi All,
First attempt to a modeless form to print to pdf the current open sheet. I’m following the modeless form example from pyRevitMEP.
I get an error. “Starting a transaction from an external application running outside of API context is not allowed.”
Any suggestions ?
Jean-Marc
(Jean-Marc Couffin)
2
This is how it is done the color splasher tool for example
I actually solved by looking at the “Rename Views” tool from pyRevitMEP.
Jean-Marc
(Jean-Marc Couffin)
4
Would you care pointing at the error in your code and how you solved it, so that it can help others?
Pretty good solution by Cyril!
