Print Sheets - no page settings
I try to use Print Sheets tool but for some reason I don’t have a list of sheets sizes (A3, A2, A1 etc) on page settings list. I also tried to use Variable Paper Size and follow the guide with Print Setting but with no luck. Can someone guide me a bit and tell me what i should do to make it work?
Have you tried changing another printer in the first dropdown?
Also, is your revit in another language than English?
Hello Marc,
My Revit is in English, I have the last version of pyrevit 5 (5.2.0.25181+1332). Also I have tried all the printer I have installed, virtual or physical and no one have any sheet size. What I have found is that I have to add all the format I want to use via print setup.
