Preflight Checks Issue
This is my first post.
Sorry if mistackes
Using Revit 2023.
pyRevit v4.8.16.24121
When I run preflight Checks, I got following Error
I have followed the recommendation shared here
However it didn’t fix the issue
Thanks for advices
Regards
Christian
/* Chart.js */ @keyframes chartjs-render-animation{from{opacity:.99}to{opacity:1}}.chartjs-render-monitor{animation:chartjs-render-animation 1ms}.chartjs-size-monitor,.chartjs-size-monitor-expand,.chartjs-size-monitor-shrink{position:absolute;direction:ltr;left:0;top:0;right:0;bottom:0;overflow:hidden;pointer-events:none;visibility:hidden;z-index:-1}.chartjs-size-monitor-expand>div{position:absolute;width:1000000px;height:1000000px;left:0;top:0}.chartjs-size-monitor-shrink>div{position:absolute;width:200%;height:200%;left:0;top:0}
**IronPython Traceback:**
File "C:\Users\kluges1\AppData\Roaming\pyRevit-Master\extensions\pyRevitTools.extension\pyRevit.tab\Project.panel\Preflight Checks.pushbutton\script.py", line 38, in <module>
File "C:\Users\kluges1\AppData\Roaming\pyRevit-Master\extensions\pyRevitTools.extension\pyRevit.tab\Project.panel\Preflight Checks.pushbutton\script.py", line 32, in ask_for_preflight_checks
File "C:\Users\kluges1\AppData\Roaming\pyRevit-Master\pyrevitlib\pyrevit\preflight\__init__.py", line 69, in run_preflight_check
File "C:\Users\kluges1\AppData\Roaming\pyRevit-Master\extensions\pyRevitTools.extension\checks\modelchecker_check.py", line 1241, in startTest
File "C:\Users\kluges1\AppData\Roaming\pyRevit-Master\extensions\pyRevitTools.extension\checks\modelchecker_check.py", line 1167, in checkModel
AttributeError: 'NoneType' object has no attribute 'Name'
**Script Executor Traceback:**
System.MissingMemberException: 'NoneType' object has no attribute 'Name'
à Microsoft.Scripting.Interpreter.ThrowInstruction.Run(InterpretedFrame frame)
à Microsoft.Scripting.Interpreter.Interpreter.Run(InterpretedFrame frame)
à Microsoft.Scripting.Interpreter.LightLambda.Run3[T0,T1,T2,TRet](T0 arg0, T1 arg1, T2 arg2)
à System.Dynamic.UpdateDelegates.UpdateAndExecute2[T0,T1,TRet](CallSite site, T0 arg0, T1 arg1)
à IronPython.Compiler.Ast.DynamicGetMemberExpression.GetMemberInstruction.Run(InterpretedFrame frame)
à Microsoft.Scripting.Interpreter.Interpreter.HandleException(InterpretedFrame frame, Exception exception)
à System.Dynamic.UpdateDelegates.UpdateAndExecute4[T0,T1,T2,T3,TRet](CallSite site, T0 arg0, T1 arg1, T2 arg2, T3 arg3)
à IronPython.Compiler.Ast.CallExpression.Invoke2Instruction.Run(InterpretedFrame frame)
à Microsoft.Scripting.Interpreter.LightLambda.Run4[T0,T1,T2,T3,TRet](T0 arg0, T1 arg1, T2 arg2, T3 arg3)
à IronPython.Compiler.PythonCallTargets.OriginalCallTarget3(PythonFunction function, Object arg0, Object arg1, Object arg2)
à Microsoft.Scripting.Interpreter.FuncCallInstruction`6.Run(InterpretedFrame frame)
à Microsoft.Scripting.Interpreter.LightLambda.Run6[T0,T1,T2,T3,T4,T5,TRet](T0 arg0, T1 arg1, T2 arg2, T3 arg3, T4 arg4, T5 arg5)
à System.Dynamic.UpdateDelegates.UpdateAndExecute5[T0,T1,T2,T3,T4,TRet](CallSite site, T0 arg0, T1 arg1, T2 arg2, T3 arg3, T4 arg4)
à Microsoft.Scripting.Interpreter.FuncCallInstruction`8.Run(InterpretedFrame frame)
à Microsoft.Scripting.Interpreter.DynamicInstruction`6.Run(InterpretedFrame frame)
à Microsoft.Scripting.Interpreter.LightLambda.Run5[T0,T1,T2,T3,T4,TRet](T0 arg0, T1 arg1, T2 arg2, T3 arg3, T4 arg4)
à Microsoft.Scripting.Interpreter.DynamicInstruction`5.Run(InterpretedFrame frame)
à Microsoft.Scripting.Interpreter.LightLambda.Run1[T0,TRet](T0 arg0)
à Microsoft.Scripting.Interpreter.DynamicInstruction`3.Run(InterpretedFrame frame)
à Microsoft.Scripting.Interpreter.LightLambda.Run2[T0,T1,TRet](T0 arg0, T1 arg1)
à IronPython.Compiler.PythonScriptCode.RunWorker(CodeContext ctx)
à PyRevitLabs.PyRevit.Runtime.IronPythonEngine.Execute(ScriptRuntime& runtime)
Looks like someone has missed a potential error/null generator later in the code, as it’s asking a null for it’s Name property. Focus these days is on pyRevit5 so I doubt you’ll get bug fixes for 4.8.x builds.
It hurts my eyes and make them bleed when I look at this code that is old and dated when I think about my understanding of python in general…
This is happening because your file is not workshared, worksets aren’t activated.
I will try and fix that in wip installers
That would be me from the past :face_with_hand_over_mouth::grin:
me from the future… :crazy_face:
I fixed that already, it is in the develop branch, meaning you can install WIP installers and get that change
Fix Model Checker Attribute Error · pyrevitlabs/pyRevit@d364f37 · GitHub
