I’m using Revit 2025.4 with pyRevit version 5.1.0.
I have an architecture model with 550,000+ elements and 41 worksets (client driven). When I run the Elements per Workset preflight check, it takes a while to run and at some point the outline of the results window appears then Revit crashes and closes soon after without showing the results. The script does take a few minutes to run on some of the other models without crashing, but those models don’t have has many elements in them.
Has anyone else encountered this issue? Is there a limit to the number of elements that the script can support and process? Is it too much to publish in the results window?
cheers,
Jason C.
