Hi Guys,
I can’t find prefight check on my pyRevit tab, am I missing something? Any help/idea?
Thanks
Adam
You’ll probably need to give us a bit more info than that
What version of Revit and pyRevit are you using? Has it always been missing? You could also upload a screenshot of your pyRevit ribbon.
@Adam-H
also try and run in the command line ‘pyrevit env’ and post the result
that will give us insights like revit version, pyrevit version and if installed properly, …
