How often in the later stages of a project do you realize that someone moves by mistake slightly on or many grid? I might argue that I should pin it … well not even this prevents the user from moving it.
Solution
I’m considering saving the intersection locations (as points) of those grids to a CSV file. This way, I can compare them to identify any changes and pinpoint at least two grids that have been relocated.
Question
there is any representation of a point in Pyrevit like in Dynamo? if yes would you please point me on that?
if not how would you face this challenge
I passed your question on to chat GPT. Here’s it’s suggestion:
To address this challenge using Python and the Revit API, you can follow these general steps:
Accessing Grids:
Use the Revit API to access the grid elements in your project.
Extracting Grid Information:
Retrieve the necessary information from each grid, such as its location (intersection points).
Storing Data:
Save the grid information (intersection points) into a data structure, like a list or dictionary.
Comparing Changes:
During subsequent runs, compare the current grid information with the previously stored data to identify any changes.
Detecting Relocations:
Pinning grids might not prevent movement, but you can use the API to detect changes in grid locations. If the stored points differ from the current ones, you’ve detected a relocation.
Logging Changes:
Log or output the identified changes, specifying which grids have been relocated.
Here’s a basic example using RevitPythonShell:
import csv
from Autodesk.Revit.DB import FilteredElementCollector, BuiltInCategory
# Step 1: Accessing Grids
grid_category = BuiltInCategory.OST_Grids
grid_collector = FilteredElementCollector(doc).OfCategory(grid_category)
# Step 2: Extracting Grid Information
grid_data = []
for grid in grid_collector:
# Retrieve grid information, including its location
grid_info = {
"Name": grid.Name,
"Location": grid.Curve.GetEndPoint(0).ToString() # Example, adjust based on your needs
grid_data.append(grid_info)
# Step 3: Storing Data
# Save grid_data to a CSV file
csv_path = r'C:\Path\to\your\grid_data.csv'
with open(csv_path, 'w', newline='') as csvfile:
fieldnames = ["Name", "Location"]
writer = csv.DictWriter(csvfile, fieldnames=fieldnames)
writer.writeheader()
for grid_info in grid_data:
writer.writerow(grid_info)
# Now, on subsequent runs, you can read the CSV file, compare and detect changes.
Remember to adapt the code based on your specific needs and project structure. This is a starting point, and you may need to enhance it depending on the complexity of your project and requirements.
i prefer version control for this because it’s accessible by anyone and can be pointed to when coordinating with other teams.
if you use ACC, you could set up a view with elements you want to monitor and will see the changes when comparing versions.
this applies to other solutions as well, e.g. comparing versions of IFC files in a IFC viewer or using other platforms with version control systems like Dalux or Revizto.
nice one it is actually getting the “GetEndPoint” so the a can retrieve for each element instead of narrowing down things via a selection of intersection points.
