author = “Mathupathy”
copyright = “Copyright (C) 2023 Mathupathy”
license = “DSM SOFT”
import Autodesk.Revit.DB
clr.AddReference(‘RevitAPI’)
clr.AddReference(‘RevitAPIUI’)
DB = Autodesk.Revit.DB
uidoc = revit.ActiveUIDocument
doc = uidoc.Document
view = uidoc.ActiveView
pt_overrides = view.GetPointCloudOverrides()
tx = Transaction(doc, ‘My Transaction Name’)
Check if point cloud overrides are available
if pt_overrides is None:
TaskDialog.Show(“Error”, “The active view does not support point cloud overrides.”)
raise Exception(“Point cloud overrides are not available in this view.”)
Get all point cloud instances in the model
pts = DB.FilteredElementCollector(doc).OfClass(DB.PointCloudInstance).WhereElementIsNotElementType().ToElements()
Check if any point cloud instances were found
if len(pts) == 0:
TaskDialog.Show(“Information”, “There are no point cloud instances in the model.”)
# Create a new transaction and start it
tx = Transaction(doc, ‘Point Cloud Color Mode Change’)
tx.Start()
# Determine the current color mode
current_mode = pt_overrides.GetPointCloudScanOverrideSettings(pts[0].Id).ColorMode
# Change the color mode for each point cloud instance
pt_cloud_settings = DB.PointClouds.PointCloudOverrideSettings()
if current_mode == DB.PointCloudColorMode.NoOverride:
pt_cloud_settings.ColorMode = DB.PointCloudColorMode.Normals
elif current_mode == DB.PointCloudColorMode.Normals:
pt_cloud_settings.ColorMode = DB.PointCloudColorMode.FixedColor
elif current_mode == DB.PointCloudColorMode.FixedColor:
pt_cloud_settings.ColorMode = DB.PointCloudColorMode.Intensity
elif current_mode == DB.PointCloudColorMode.Intensity:
pt_cloud_settings.ColorMode = DB.PointCloudColorMode.Elevation
pt_cloud_settings.ColorMode = DB.PointCloudColorMode.NoOverride
for pt in pts:
pt_overrides.SetPointCloudScanOverrideSettings(pt.Id, pt_cloud_settings)
# Commit the transaction
tx.Commit()
# Show a message indicating success
TaskDialog.Show("Success", "Point cloud color mode has been changed to Normals.")
TaskDialog.Show("Success", "Point cloud color mode has been changed to FixedColor.")
TaskDialog.Show("Success", "Point cloud color mode has been changed to Intensity.")
TaskDialog.Show("Success", "Point cloud color mode has been changed to Elevation.")
TaskDialog.Show("Success", "Point cloud color mode has been changed to NoOverride.")
I am made plugin for point cloud colour mode change. its perfectly working on revit 2022 not working on revit 2016
it shows error point cloud dont have colour override
