Is there a way to create a sound when a script finishes or with a hook for standard Revit events? I find it frustrating sometimes having to wait for some commands to finish and I think it would help if I had a audible notification so I could switch to some other task rather than stare at my screen.
Not asking for code or anything just a starting point for research. Thanks
Using a toast in the script means the sound plays when the script finishes, but that is not necessarily when the UI becomes available again.
I use this with my C# ribbon to trigger things once the UI is responsive, which is sometimes 30-40 seconds later if I’m updating 1000s of elements at once and triggering and IUpdater after the command completes.
private void OnIdling(object sender, IdlingEventArgs e)
SystemSounds.Beep.Play(); // This is the familiar system notification chime
//SystemSounds.Asterisk.Play();
//SystemSounds.Exclamation.Play();
//SystemSounds.Hand.Play();
//SystemSounds.Question.Play();
if (sender is UIApplication uiApp)
uiApp.Idling -= OnIdling;
Should be fairly straight forward to translate this to python, although you will have to come up with a way to subscribe to the OnIdling event when the command is executed. In my use case I’m using reflection to load the IExternalCommand from a separate DLL so I handle all of this in the method in my application that is calling the command.
You would need to make a hook that is triggered by specific commands or you would end up getting a chime every time you press a button.
