Pdf namingrules
Might my monday startup but when setting a generic namingrule as one would do manually (File > PDFexport > namingrule)
We can pick settings from veiws, projectinformation and sheets.
I want to grab a parameter which is from a shared parameter file.
	namingrule = DB.TableCellCombinedParameterData.Create()
	namingrule.CategoryId = DB.ElementId(DB.BuiltInCategory.OST_Sheets)
	namingrule.Prefix = ""
	namingrule.ParamId = DB.ElementId(DB.BuiltInParameter.SHEET_NUMBER)
	namingrule.SampleValue = ""
	namingrule.Suffix = ""
	namingrule.Separator = ""
The above works as expected but now the DB.ElementId(DB.BuiltInParameter.SHEET_NUMBER) should be
sheet.lookupparameter("myparam").
But as it is generic “sheet” isn’t available. How do I get this parameter?
I tried
param_guid = Guid("6a7dbe6d-aedc-4c88-a2cf-f5ece36287c0")
test = DB.ElementId(param_guid)
It feels like I’m close but my head is foggy or so. Any thoughts?
Not sure this is possible
Perhaps another approach? Doing this manually works.
Ughh.
For now I’m gonna loop through the sheet to get the param.Id … horrible approach. If someone has a clue: please do share!
I’m not sure I follow…
If you just want a particular shared parameter in a project:
params = FilteredElementCollector(doc).OfClass(SharedParameterElement).ToElements()
paramset = []
for p in params:
	if p.Name == "Depth":
		paramset.append(p)
print(paramset)
From there you can get the definition, ID, guid and other information.
But to get the data - you need to get the information from the object - such as the sheet.
And note that Revit doesn’t clean up shared parameters and you can have multiple shared parameters f the same name (my example above returns two in our template) all pointing to different things. Also, old deleted shared parameters aren’t really deleted - just kind of hidden.
If you want the parameters related to a sheet - you don’t have to loop all the sheets. One sheet will do. FilteredElementCollector(doc).OfClass(ViewSheet).FirstElement() is fast and gives you the first sheet it finds. From there just get Parameters, ParametersMap or GetOrderedParameters() depending on what you’re doing.
def getparam(doc)
	sheet = FilteredElementCollector(doc).OfClass(ViewSheet).FirstElement()
	params = sheet.GetOrderedParameters()
	for param in params:
		if param.Definition.Name == "Sheets Submittal Date 02":
		return param
Note: The above gets the first parameter it finds with the name. So, if you have several of the same name on the same object class - you have to further check. (Does happen.) Same as the LookUpParameter.
