Bonjour, je doit recharger à chaque utilisation les paramètres UI/UX.
Ils ne s’enregistrent pas correctement et je dois recommencer.
Bonjour,
Le forum est en anglais, et il faut donner pas mal plus de contexte pour que les participants puissent comprendre et aider à résoudre la question.
Hello, following the installation of revit 2027.1, we reinstalled pyRevit v6.5.3. it is unstable and does not display correctly. Every time a Revit folder is loaded, the tabs do not color out and the menu remains in English despite the request in the settings to set it to French.
Did you by any chance mix admin and user installers? Admin seeds the config from ProgramData, and that doesn’t seem to work reliably or isn’t clear to everyone.
If that is not the case, please file an issue report on github.
