Hello pyRevit friends ![]()
I have a tool that sets pre defined overrides to view filters.
I now want to make a tool that sets a custom override to a view filter, so the user can decide which overrides he want to set.
My only idea to do this is to use a command switch form as a first step and let the user decide what he wants to override.
Enable/Visible/Projection Line/Projection Pattern/Transparency/Cut Lines/Cut Pattern/Halftone.
Then i would need the next form to let the user decide what he wants to set:
Pattern/color/weight.
Thats all not very user friendly, specially if you want to set multiple overrides.
So I would like to know if there is a better way to do this with pyRevit.
If not i would like to know if this is something other users would also like, so maybe in the future pyRevit could get a form like this:
That would help to make this process more convenient.
Appreciate any advice!
Kind regards
