Wondering if there is a way to open the currently assigned view template menu. Tried searching for something like this in the API but can’t find anything for opening any menu.
Not that I know of, the postablecommand way is not available.
In the property palette, there is only the view range available as a shortcut.
you are not the only one… Re: RevitCommandId to open "Assign View Template" window - Autodesk Community
