'NoneType' object has no attribute 'VersionNumber'
Hi everyone,
After updating to pyRevit 5.3.1, and occasionally when switching between different Revit versions, we’ve started getting the following error:
‘NoneType’ object has no attribute ‘VersionNumber’
It appears to be triggered by the hooks/doc-updater script.
The issue seems to originate from this file:
AppData\Roaming\pyRevit-Master\pyrevitlib\pyrevit\__init__.py
Further investigation (and a few additional related error messages) suggests that pyRevit is unable to find the app, possibly related to HOS_APP or a similar reference. The only reliable workaround so far has been to disable the doc-updater hook, which we’d prefer not to do.
The line in our doc-updater.py that triggers the issue is:
from pyrevit import EXEC_PARAMS, revit
Occasionally, we also get an error referring to the engine attribute:
File "X:\All 1 DATABASE\00_Python_Tools\All 1 Special.extension\hooks\doc-updater.py", line 4, in <module>
File "<string>", line 540, in _check_name_wrapper
File "C:\Users\ALL1-PC10\AppData\Roaming\pyRevit-Master\pyrevitlib\pyrevit\__init__.py", line 88, in <module>
File "<string>", line 1565, in load_module
File "<string>", line 597, in _load_module_shim
File "<string>", line 1208, in load
File "<string>", line 1188, in _load_unlocked
File "<string>", line 1117, in _exec
File "<string>", line 1459, in exec_module
File "<string>", line 322, in _call_with_frames_removed
AttributeError: 'module' object has no attribute 'engine'
I know this is a bit of an odd one, but any help, insight, or suggestions would be greatly appreciated—especially if there’s a way to keep the doc-updater enabled.
Thanks!
Ok, for now I have a working solution, though I’m not entirely sure why this happens.
It turns out there’s an issue with the revit module in pyRevit. The doc-updater hook only works if the revit module has been imported beforehand. For example, when we first run another hook (we tested with a DWG import hook) that includes:
from pyrevit import revit
then the doc-updater hook runs without any problems. It seems the revit module needs to be loaded first, though the reason isn’t clear.
As a workaround, we added an app-init.py hook that ensures the revit module is always loaded on application start. With this in place, the doc-updater hook works as expected.
This is just a workaround for now. If anyone knows why this happens or how it might be prevented in future pyRevit versions, your insights would be greatly appreciated.
Your right, this looks like an initialization issue
I would try
def doc_updater_function():
    # your code here
Or add a safety check:
except AttributeError:
I just tried to put the import inside my doc_updater_function(), but unfortunately, this doesn’t work.
I will stick to the app-init hook and import there for now.
