I’m getting an error when running this code. Can’t figure out what is going wrong. I get the same error when I provide a dimension type. The error is referring to the NewLinearDimension method.
File “L:\Revit\Development\PyRevit\DevTool\DevTool.extension\DevTools.tab\Development.Panel\JustTesting.pushbutton\JustTesting_script.py”, line 90, in
Exception: One of the conditions for the inputs was not satisfied. Consult the documentation for requirements for each argument.
# Testing Script experiments
import datetime
# Import libraries
from pyrevit import DB, revit, script, forms
from rpw.ui.selection import Pick
clr.AddReference('RevitAPI')
import Autodesk
from Autodesk.Revit.UI import RevitCommandId
from Autodesk.Revit.UI import ExternalCommandData
import RevitServices
import System
# doc = DocumentManager.Instance.CurrentDBDocument
# uiapp = DocumentManager.Instance.CurrentUIApplication
cView = doc.ActiveView
# Debug toggles
globalDebug = True
disabledScript = False
def dprint(*printItems):
if globalDebug:
for pI in printItems:
print(pI)
#Create Reference plane
t = Transaction(doc, "pyRevit - Create Reference Plane")
famMan = doc.FamilyManager
dimTypeId = doc.GetDefaultElementTypeId(ElementTypeGroup.LinearDimensionType)
dprint(dimTypeId)
dimType = doc.GetElement(dimTypeId)
# Parameters
# Label __ Left Right
famMan.AddParameter("Label __ Left Right", GroupTypeId.Constraints, SpecTypeId.Length, True)
# Label __ Off Wall
famMan.AddParameter("Label __ Off Wall", GroupTypeId.Constraints, SpecTypeId.Length, True)
# Label_Dim_LeftCorrection
famMan.AddParameter("Label_Dim_LeftCorrection", ForgeTypeId(), SpecTypeId.Length, True)
# Label_Dim_OffsetFromWallCorrection
famMan.AddParameter("Label_Dim_OffsetFromWallCorrection", ForgeTypeId(), SpecTypeId.Length, True)
p = Plane.CreateByNormalAndOrigin(XYZ.BasisZ, XYZ(0, 0, 0))
sp = SketchPlane.Create(doc, p)
# Ref Plane Label Anchor
refSymbolAnchorLeft = doc.FamilyCreate.NewReferencePlane(XYZ(-3,-1,0),XYZ(-3,1,0), XYZ(0,0,1), cView)
refSymbolAnchorLeft.Name = "Symbol Anchor"
refSymbolAnchorLeft.Pinned = True
refSymbolAnchorLeft.LookupParameter("Is Reference").Set(12)
# Ref Line Label Vertical Center
lsvc = Line.CreateBound(XYZ(2, -2, 0), XYZ(2, -4, 0))
lineSymbolVerticalCenter = doc.FamilyCreate.NewModelCurve(lsvc, sp)
lineSymbolVerticalCenter.ChangeToReferenceLine()
# Create Dimension
ra = ReferenceArray()
ra.Append(refSymbolAnchorLeft.GetReference())
ra.Append(lineSymbolVerticalCenter.GeometryCurve.Reference)
dimline = Line.CreateBound(XYZ(2, -5, 0), XYZ(-3, -5, 0))
dprint(cView)
dprint(dimline)
dprint(ra)
dprint(ra.IsEmpty)
dprint(ra.Size)
dprint(ra.Item[0])
dprint(ra.Item[1])
dprint(dimType)
dim = doc.FamilyCreate.NewLinearDimension(cView, dimline, ra)
