I noticed that manually installing different versions of pyRevit is possible i.e it doesnt overwrite or remove the old version before installing the new one (in registry). Is it this intended? Im aware of the ability for updating pyRevit via the ribbon but I am creating a tool to manage software/plugins installed and noticed this with pyRevit.
Ive taken a brief look at the docs but cant find anything discussing this. When looking in the bin folder its clear that the dll’s are only for the last installed version but when looking at the registry and/or Apps & Features you can clearly see that it indicates both versions are installed.
I just need confirmation:
- Is it possible to install several versions of pyRevit on the same user/machine?
- If it is (unlikely due to what im seeing), is the reason behind this that different Revit versions might only support certain versions of pyRevit? Where are the dll’s for each version installed?
- If this is not intended I assume this is something related to the installer, I can look into this and create an issue on github
Thanks!
