Multiple string input
Hi, im trying to collect 2 strings from the user while using only one pop up menu.
something like forms.ask_for_string
only for two instead of one.
does anybody knows how can it be done?
Thanks
forms.ask_for_string(
    default='some-tag',
    prompt='Enter new tag name:',
    title='Tag Manager'
@IdoRevit
actually i can`t follow you
do you want to get the inputs of 2 Parameters from an element ?
should the strings match by a key ?
When you use forms.ask_for_string() you can only collect one string input at a time.
I want to collect 2 ( key and the value of the parameter in my case) at a time.
Right now the procces from the user end looks like this:
input 1st string → click ok → input 2nd string → click ok → script continue to run…
I want it to be:
input 1st string & 2nd string-> click ok → script continue to run…
just use it twice :slight_smile:
@Tomasz
you mean like “concacinate” ?
I’d go for wpf window with two textboxes. It’s fairly easy solution and user friendly.
@IdoRevit, you can use the FlexForm class found within the Revit Python Wrapper (rpw) which comes shipped with pyRevit. You could do something like…
from rpw.ui.forms import FlexForm, TextBox, Button
components = [TextBox('textbox1', Text='default text1'),
              TextBox('textbox2', Text='default text2'),
              Button('OK')]
form = FlexForm('Title', components)
form.show()
Haven’t personally been able to get this to work on my install of pyRevit, but I’ve seen others use it to do exactly what you’re looking for.
rpw
WPF is the way to go, but Windows Forms could also work.
Here is a sample for setting up a custom WPF to get you started.
Add this xaml code in a file inside your .pushbutton, name the file “CustomForm.xaml”:
        Title="Form Title" Height="180" Width="410">
    <Grid Margin="10">
        <Grid.RowDefinitions>
            <RowDefinition Height="Auto"/>
            <RowDefinition Height="20"/>
        </Grid.RowDefinitions>
        <Grid.ColumnDefinitions>
            <ColumnDefinition Width="Auto"/>
            <ColumnDefinition Width="*"/>
        </Grid.ColumnDefinitions>
        <TextBlock Grid.Row="0" Grid.Column="0" VerticalAlignment="Center" Margin="5">Input value 1:</TextBlock>
        <TextBox Name="InputValue1TextBox" Grid.Row="0" Grid.Column="1" Margin="5"/>
        <TextBlock Grid.Row="1" Grid.Column="0" VerticalAlignment="Center" Margin="5">Input value 2:</TextBlock>
        <TextBox Name="InputValue2TextBox" Grid.Row="1" Grid.Column="1" Margin="5"/>
        <Button Name="OkButton" Grid.Row="3" Grid.Column="1" Width="170" Margin="5" HorizontalAlignment="Right" Click="OkButton_Click">OK</Button>
        <Button Name="CancelButton" Grid.Row="3" Grid.Column="0" Width="170" Margin="5" HorizontalAlignment="Right" Click="CancelButton_Click">Cancel</Button>
    </Grid>
</Window>
Script to open the form, fetch the input and print it:
import wpf
from System.Windows import Window
from pyrevit import revit
# Create a class for the custom form
class CustomForm(Window):
    def __init__(self):
        xaml_path = os.path.join(os.path.dirname(__file__), 'CustomForm.xaml')
        wpf.LoadComponent(self, xaml_path)
    # Handler for the OK button
    def OkButton_Click(self, sender, e):
        input_value_1 = self.InputValue1TextBox.Text
        input_value_2 = self.InputValue2TextBox.Text
        # Do something with the inputs
        self.DialogResult = True  # Set the dialog result as true to close the window
        self.Close()
    # Handler for the Cancel button
    def CancelButton_Click(self, sender, e):
        self.DialogResult = False  # Set the dialog result as false to indicate cancellation
        self.Close()
# Main pushbutton logic
def main():
    custom_form = CustomForm()
    # Show the form and capture the dialog result
    if custom_form.ShowDialog():
        input_value_1 = custom_form.InputValue1TextBox.Text
        input_value_2 = custom_form.InputValue2TextBox.Text
        # Process the input values here
        # For example, print them
        print("Input Value 1:", input_value_1)
        print("Input Value 2:", input_value_2)
with revit.Transaction('Use Custom Form'):
    main()
With this you can use the “input_value_1” and “input_value_2” as variables for the rest of your script.
Thank you guys for your answers.
both solutions from @pete.heibel and @Jonn.O works.
The solution from Pete is more simple and fits my case well, although Ill keep Jonn’s solution in my mind, it might be helpfull in other cases.
