Multiple override graphic settings in one transaction
Im fairly knew to python and the revit api.
I’m attempting to set an object transparent and halftone. The code below only sets the element to halftone. But if i comment out the halftone, it will set the element to transparent… Im not sure why it wont set both.
clr.AddReference('RevitAPI')
app = __revit__.Application
selection = [doc.GetElement(x) for x in uidoc.Selection.GetElementIds()]
t = Transaction(doc, 'transparenthalftone')
for i in selection:
    doc.ActiveView.SetElementOverrides((i.Id),
    OverrideGraphicSettings().SetSurfaceTransparency(100)
	OverrideGraphicSettings().SetHalftone(True))
__window__.Close()
you need to create a instance of graphics overrides and then just use another overload of SetElementOverrides which takes elementId and OverrideGraphicSettings as inputs.
sth like
ogs = OverrideGraphicSettings()
ogs.SetProjectionFillColor(R,G,B)
ogs.SetProjectionLineColor(R,G,B)
ogs.SetProjectionFillPatternId(pattern.Id)
ogs.SetSurfaceTransparency(100)
ogs.SetHalftone(True)
for i in selection:
    doc.ActiveView.SetElementOverrides(i.Id, ogs)
In your code → only the last override would be applied
Thanks Tomasz! that worked.
I was hoping to get some feedback for graphic settings. I have a similar task. I want to be able to make all the grid lines/bubbles in the all the views not half toned. This is what i have but it doesn’t take. It runs through with no issues but my grids are still haftone. any ideas where it is failing to uncheck the halftone in the visibility graphics?
For now i am trying to make it work for the active view and if that works, then i can swap it for all the views.
active_view = uidoc.ActiveView
# Check if the active view is a valid view
if active_view is None or active_view.IsTemplate:
    TaskDialog.Show("Error", "No valid active view found.")
    t = Transaction(doc, 'Modify Grid Halftone')
        # Get all grid elements in the active view
        collector = FilteredElementCollector(doc, active_view.Id).OfCategory(BuiltInCategory.OST_Grids)
        grids = [grid for grid in collector.ToElements()]
        for grid in grids:
            # Modify halftone setting for grid
            overrides = active_view.GetElementOverrides(grid.Id)
            overrides.SetHalftone(False)
        # Commit the transaction
        TaskDialog.Show("Success", "Halftone setting for grid annotations updated.")
        # Roll back the transaction if an error occurs
        t.RollBack()
        TaskDialog.Show("Error", "An error occurred: {}".format(e))```
from pyrevit import revit, DB, HOST_APP, forms
active_view = HOST_APP.active_view
with revit.Transaction("reset halftone for grids"):
    grids = DB.FilteredElementCollector(doc, active_view.Id).OfCategory(DB.BuiltInCategory.OST_Grids).ToElements()
    print(len(grids))
    for grid in grids:
        ogs = DB.OverrideGraphicSettings()
        ogs.SetHalftone(False)
        active_view.SetElementOverrides(grid.Id, ogs)
    forms.alert("Halftone settings for grids annotations reset suceeded.")
I simplified it, the Graphics overrides are per view, so you set the element overrides of the view for a specific element:
  1. declare OG
  2. set the property you want to change in this OG bucket
  3. apply it to the view with the SetElementOverrides method with two arguments: element.Id of the element you want to change the graphics, your OG bucket
Jean, it did not seem to apply the reset. the grids/bubbles remained as halftone.
Could this be my model perhaps?
It works in my very simple project.
Make a new bare model with only grids and overrides per element as halftone
Element override or category override (VV/VG)? Or grids in a linked file (cannot be controled this way)? Or is a workset and all non active worksets are set to display halftone.
ohhh, i see now. It is element specific.
I failed to convey this message. I was referring to the halftone button in the Visibility Graphics Override
Did you find a solution?
