Modify the parameter of selected parts
I’ve created a very simple Dynamo parameter :
When I try to use this script with Pyrevit, it doesn’t work. It’s only launching the parameter modification, but I can’t change the part selected.
My goal is to select one part, launch the script by a pyrevit button, and it applies the parameter changes on the selected part.
Any ideas ?
Is ‘Select model elements…’ node set as input?
Yes. When I’m directly using this script in Dynamo. I click on “Select”, I chose the parts I want, I confirm, then I launch the script and it works.
But when I use a Pyrevit button, I don’t have this selection possibility
Just to make sure we are on equal footing. Sorry if I’m nitpicking, but did you set node as input so it would work correctly also in Dynamo Player:
1000001338
I confirm I did it. It works with Dynamo, Dynamo player, but not with pyrevit
Then I’ll have to send you to previous topic
