for the edited python script
# -*- coding: UTF-8 -*-
from __future__ import print_function
from pyrevit import script, forms, revit, HOST_APP
from pyrevit.revit import dc3dserver as d3d
import traceback
from Autodesk.Revit import DB, UI
from Autodesk.Revit.UI.Events import ViewActivatedEventArgs, SelectionChangedEventArgs
from Autodesk.Revit.DB.Events import DocumentChangedEventArgs
from System import EventHandler, Convert
from System.Windows.Media import Color, SolidColorBrush
uidoc = revit.uidoc
logger = script.get_logger()
output = script.get_output()
PLANES = {
DB.PlanViewPlane.TopClipPlane: [0, 255, 0],
DB.PlanViewPlane.CutPlane: [255, 0, 0],
DB.PlanViewPlane.BottomClipPlane: [0, 0, 255],
DB.PlanViewPlane.ViewDepthPlane: [255, 127, 0]
class SimpleEventHandler(UI.IExternalEventHandler):
Simple IExternalEventHandler sample
def __init__(self, do_this):
self.do_this = do_this
def Execute(self, uiapp):
self.do_this(uiapp)
except InvalidOperationException:
print('InvalidOperationException catched')
def GetName(self):
return "SimpleEventHandler"
class Context(object):
def __new__(cls, *args, **kwargs):
if not hasattr(cls, "instance"):
cls.instance = super(Context, cls).__new__(cls, *args, **kwargs)
return cls.instance
def __init__(self, view_model):
self._active_view = None
self._source_plan_view = None
self.length_unit = (doc.GetUnits()
.GetFormatOptions(DB.SpecTypeId.Length)
.GetUnitTypeId())
self.height_data = {}
self.view_model = view_model
view_model.unit_label = DB.LabelUtils.GetLabelForUnit(self.length_unit)
@property
def active_view(self):
return self._active_view
@active_view.setter
def active_view(self, value):
self._active_view = value
self.context_changed()
@property
def source_plan_view(self):
return self._source_plan_view
@source_plan_view.setter
def source_plan_view(self, value):
self._source_plan_view = value
def context_changed(self):
server.uidoc = UI.UIDocument(self.active_view.Document)
if not self.is_valid():
server.meshes = None
refresh_event.Raise()
self.view_model.topplane_elevation = "-"
self.view_model.cutplane_elevation = "-"
self.view_model.bottomplane_elevation = "-"
self.view_model.viewdepth_elevation = "-"
return
def corners_from_bb(bbox):
transform = bbox.Transform
corners = [
bbox.Min,
bbox.Min + DB.XYZ.BasisX * (bbox.Max - bbox.Min).X,
bbox.Max,
bbox.Min + DB.XYZ.BasisY * (bbox.Max - bbox.Min).Y
return [transform.OfPoint(c) for c in corners]
if self.active_view.get_Parameter(
DB.BuiltInParameter.VIEWER_MODEL_CLIP_BOX_ACTIVE
).AsInteger() == 1:
bbox = self.active_view.GetSectionBox()
bb_corners = corners_from_bb(bbox)
bb_corners = None
view_range = self.source_plan_view.GetViewRange()
edges = []
triangles = []
for plane in PLANES:
plane_level = self.source_plan_view.Document.GetElement(
view_range.GetLevelId(plane)
if bb_corners:
corners = bb_corners
level_bbox = plane_level.get_BoundingBox(self.active_view)
corners = corners_from_bb(level_bbox)
plane_elevation = (
plane_level.ProjectElevation
+ view_range.GetOffset(plane)
read_elevation= (
self.height_data[plane] = str(round(
DB.UnitUtils.ConvertFromInternalUnits(
read_elevation,
self.length_unit
2
))+" from ("+plane_level.Name+")"
cut_plane_vertices = [
DB.XYZ(c.X, c.Y, plane_elevation) for c in corners
color = DB.ColorWithTransparency(
PLANES[plane][0],
PLANES[plane][1],
PLANES[plane][2],
180
edges.extend([
revit.dc3dserver.Edge(
cut_plane_vertices[i-1],
cut_plane_vertices[i],
color
) for i in range(len(cut_plane_vertices))
triangles.extend([
revit.dc3dserver.Triangle(
cut_plane_vertices[0],
cut_plane_vertices[1],
cut_plane_vertices[2],
revit.dc3dserver.Mesh.calculate_triangle_normal(
color
cut_plane_vertices[3],
color
mesh = revit.dc3dserver.Mesh(
edges,
triangles
server.meshes = [mesh]
self.view_model.topplane_elevation = str(self.height_data[
DB.PlanViewPlane.TopClipPlane])
self.view_model.cutplane_elevation = str(self.height_data[
DB.PlanViewPlane.CutPlane])
self.view_model.bottomplane_elevation = str(self.height_data[
DB.PlanViewPlane.BottomClipPlane])
self.view_model.viewdepth_elevation = str(self.height_data[
DB.PlanViewPlane.ViewDepthPlane])
print(traceback.format_exc())
def is_valid(self):
if not isinstance(context.source_plan_view, DB.ViewPlan):
self.view_model.message = \
"Please select a Plan View in the Project Browser!"
return False
elif not isinstance(context.active_view, DB.View3D):
self.view_model.message = "Please activate a 3D View!"
return False
self.view_model.message = "Showing View Range of\n[{}]".format(
self.source_plan_view.Name)
return True
class MainViewModel(forms.Reactive):
def __init__(self):
self._message = None
self.topplane_brush = SolidColorBrush(Color.FromRgb(
*[Convert.ToByte(i) for i in PLANES[DB.PlanViewPlane.TopClipPlane]]
self.cutplane_brush = SolidColorBrush(Color.FromRgb(
*[Convert.ToByte(i) for i in PLANES[DB.PlanViewPlane.CutPlane]]
self.bottomplane_brush = SolidColorBrush(Color.FromRgb(
*[Convert.ToByte(i) for i in PLANES[DB.PlanViewPlane.BottomClipPlane]]
self.viewdepth_brush = SolidColorBrush(Color.FromRgb(
*[Convert.ToByte(i) for i in PLANES[DB.PlanViewPlane.ViewDepthPlane]]
self._topplane_elevation = "-"
self._cutplane_elevation = "-"
self._bottomplane_elevation = "-"
self._viewdepth_elevation = "-"
self.unit_label = ""
@forms.reactive
def message(self):
return self._message
@message.setter
def message(self, value):
self._message = value
@forms.reactive
def topplane_elevation(self):
return self._topplane_elevation
@topplane_elevation.setter
def topplane_elevation(self, value):
self._topplane_elevation = value
@forms.reactive
def cutplane_elevation(self):
return self._cutplane_elevation
@cutplane_elevation.setter
def cutplane_elevation(self, value):
self._cutplane_elevation = value
@forms.reactive
def bottomplane_elevation(self):
return self._bottomplane_elevation
@bottomplane_elevation.setter
def bottomplane_elevation(self, value):
self._bottomplane_elevation = value
@forms.reactive
def viewdepth_elevation(self):
return self._viewdepth_elevation
@viewdepth_elevation.setter
def viewdepth_elevation(self, value):
self._viewdepth_elevation = value
class MainWindow(forms.WPFWindow):
def __init__(self):
forms.WPFWindow.__init__(self, "MainWindow.xaml")
self.Closed += self.window_closed
subscribe()
server.add_server()
def window_closed(self, sender, args):
server.remove_server()
unsubscribe_event.Raise()
def subscribe():
ui_app = UI.UIApplication(HOST_APP.app)
ui_app.ViewActivated += EventHandler[ViewActivatedEventArgs](view_activated)
ui_app.SelectionChanged += EventHandler[SelectionChangedEventArgs](selection_changed)
ui_app.Application.DocumentChanged += EventHandler[DocumentChangedEventArgs](doc_changed)
def unsubscribe(uiapp):
uiapp.ViewActivated -= EventHandler[ViewActivatedEventArgs](view_activated)
uiapp.SelectionChanged -= EventHandler[SelectionChangedEventArgs](selection_changed)
uiapp.Application.DocumentChanged -= EventHandler[DocumentChangedEventArgs](doc_changed)
def refresh_active_view(uiapp):
uidoc.ActiveView = context.active_view
uidoc.RefreshActiveView()
if context.source_plan_view:
uidoc.Selection.SetElementIds(List[DB.ElementId]([context.source_plan_view.Id]))
def view_activated(sender, args):
context.active_view = args.CurrentActiveView
def selection_changed(sender, args):
doc = args.GetDocument()
sel_ids = list(args.GetSelectedElements())
if len(sel_ids) == 1:
sel = doc.GetElement(sel_ids[0])
if isinstance(sel, DB.ViewPlan):
context.source_plan_view = sel
return
context.source_plan_view = None
def doc_changed(sender, args):
context.context_changed()
server = revit.dc3dserver.Server(register=False)
unsubscribe_event = UI.ExternalEvent.Create(SimpleEventHandler(unsubscribe))
refresh_event = UI.ExternalEvent.Create(SimpleEventHandler(refresh_active_view))
vm = MainViewModel()
context = Context(vm)
context.active_view = uidoc.ActiveGraphicalView
main_window = MainWindow()
main_window.DataContext = vm
main_window.show()
