Menu creation and populating the menu with data
Hello everyone. I need that when the button is pressed, a window will fly out that I could fill with families. As far as I understand, i need to connect the databases here? Where can I read about it?
Hi Andrey,
heavily based on the save family button in pyRevit, it goes like this:
# Jean-Marc Couffin, June 2021
family_dict = {}
for family in revit.query.get_families(revit.doc, only_editable=True):
    if family.FamilyCategory:
        family_dict[
            "%s: %s" % (family.FamilyCategory.Name, family.Name)
        ] = family
if family_dict:
    selected_families = forms.SelectFromList.show(
        sorted(family_dict.keys()),
        title="Select Families",
        multiselect=True,
    if selected_families:
        for idx, family in enumerate([family_dict[x] for x in selected_families]):
            print (family.Name)
            print (family)
            # or do whatever
you can find a long documentation here:
https://pyrevit.readthedocs.io/en/latest/pyrevit/forms.html
and some easier to understand examples here:
https://pyrevit1.readthedocs.io/en/latest/outputfeatures.html
Thanks Jean-Marc. And where should I keep the families themselves? I do not quite understand the logic of work.
you need to be more precise about what you expect to achieve and what you have done so far.
no help comes totally free :slight_smile:
I wanted to clarify, where do I need to store families? This can be done, through the pyrevit, or through the WPF with the connection of the SQL tables?
P.S. β€œno help comes totally free :slight_smile:”
how much does help cost today?
effort on your side :grin:
explain what you are trying to do or achieve with the script you are building.
most of the time you don’t need a database to do your things in revit with pyRevit
At the moment, an empty window, which I created following the example. I need to make an element library out of it
you want to list specific families? which ones? the ones from the active view?
Did you try the code block I provided?
You could replace the get_family(revit.doc, only_editable=True) by a get_all_elements_in_view(view)
you will therefore grab all elements in the view and then you need to work you way to the family with something like:
type_id = e.GetTypeId()
element_type = doc.GetElement(type_id)
family = element_type.Family
name = family.Name
quick and dirty for the sake of the exercise:
active_view = doc.ActiveView
family_dict = {}
for e in revit.query.get_all_elements_in_view(active_view):
        e_type = revit.query.get_type(e)
        family = e_type.Family
            family_dict[
            ] = family
if family_dict:
        multiselect=True,
            print (family.Name)
            print (family)
this is how it turns out
