Match keyboard shortcut opening windows explorer
Hi, when I set a revit keyboard shortcut to either pyrevit’s ‘match element overrides’ or ‘match properties’, the shortcut opens windows explorer with the config file selected. I would like it to behave as if I was pressing the match button. Any help would be appreciated.
Thanks,
Kyle
Hi, welcome,
What is the shortcut you are trying to assign ?
Thanks Jean-Marc! I had assigned it shift+alt+c. Just tried RRR and it worked! I had seen this page earlier but didn’t put 2 and 2 together that my shortcut was activating the alt+click option to show the script in windows explorer. I’m wanting a shortcut similar to ctrl+shift+c which I use to match property type.
I’d also be interested in using the keyboard only to ‘finish’ the process, instead of clicking the finish button. Thoughts?
Button click options
Great you found out why.
Finish button
Not to say it is impossible but probably not easy to get a shortcut on the finish button.
I know some are theoretically accessible through the shortcut list of Revit but def. not all of them _ and many, while assignable in the UI, do not do anything as they are in a state _ transaction_ where the UI is not accessible. The finish button, from the journal entry, is this line in the shortcut xml
<ShortcutItem CommandName="Finish" CommandId="IDD_MULTIPICK_DBAR:ID_FINISH_MULTI_PICK_DBAR" Paths="Contextual Tabs&gt;Multiple" />
  <ShortcutItem CommandName="Create System; Recreate System; Finish; Create Floor; Create Roof" CommandId="ID_FINISH_MULTI_PICK_DBAR" Paths="Contextual Tabs&gt;Multiple Selection; Contextual Tabs&gt;Intersects" />
Assigning a shortcut like so, did not work
  <ShortcutItem CommandName="Finish" CommandId="IDD_MULTIPICK_DBAR:ID_FINISH_MULTI_PICK_DBAR" Shortcuts="FI" Paths="Contextual Tabs&gt;Multiple" />
Technically, these are Postable command entries:
Wild guess, You could try to add an event listener in the match properties command, that would listen to keyboard keystrokes…
This was something that greatly irritated me when I started with Revit. Now I am just numbed by these bumd UX.
