"The tool will process the input lines, approximates the curves and splines with smaller lines and finds the best angles for these lines and will generate a pattern."Is it possible to turn off or reduce the degree of approximation?
The semicircle has been simplified to three lines. This is a very rough simplification.
Sample of lines:
Result:
Or are arc elements not supported and therefore have to be simplified to lines?
