Make pattern failed in diagonal line
Hello everyone, I got a trouble when try to create herringbone pattern using Make pattern
The hatch was created by Make pattern didn’t smooth. As you can see in the picture below, the pattern is on the right hand side.
I think this is a bug, because when I rotated my drawings 45 degree and created pattern again then rotated the pattern 45 degree too, it became normal
Thank you for reading my topic. I hope pyRevit can fix it on next release
this is my picture after rotate 45 degree
Since the “Make Pattern” button asks for a bottom left corner, and a top right corner to create the pattern, you have to draw the pattern horizontally and, then specify the angle after you click the button in the dialog.
