Make a message appears on button click
hello , i am new to pyrevit and i am testing a small python script with rpw.
how can i make a message appears 'hello world ’ when i click on the button named generate text?
any help would be appreciated.
and here is my UI+script
the script:
clr.AddReference("RevitAPI")
clr.AddReference('Microsoft.Office.Interop.Excel')
from rpw.ui.forms import Console, FlexForm, Label, TextBox, Button, select_file, Alert
from Microsoft.Office.Interop import Excel
t = Transaction(doc, 'Create Sheet')
components = [
    Label('Sheet Name'),
    TextBox('textbox1'),
    Label('Sheet Number'),
    TextBox('textbox2'),
    Button('select excel !'),
    Button('Generate text!')
form = FlexForm('Create sheet', components)
form.show()
def generate_button_clicked(sender, args):
    Alert("Hello there!", title="Greetings")
form.add_button('Generate text!', on_click=generate_button_clicked)
Hi @FethiSekinKız and welcome,
It does not look like a small python script to me but a rather big one if you are new to it :slight_smile:
I striped down your script a bit.
It works like so:
from rpw.ui.forms import FlexForm, Label, TextBox, Button, Alert
from pyrevit import revit
    This function is called when the 'on click do this' pushbutton is clicked. It displays an alert with the message 'Hello there!' and the title 'Greetings'.
components = [
    Button('On click do this', on_click=generate_button_clicked),
form.show()
oh thank you a lot @Jean-Marc your script worked perfectly . its like a small project i am doing by myself to practice python. i really adore your help
