Trying to loop a function that contains a PickFace…
ref = uidoc.Selection.PickObject(ObjectType.Face, "Select a face.")
But don’t want to collect a bunch of faces with the pyRevit pick_face as I’m completing a transaction on each loop for both the user feedback and the undo steps.
So I’m looking for a way to while loop and then break the loop. I would probably use import keyboard - but not installed and IT is a pita.
I’ve tried msvcrt - but that is seeing some sort of keypress inside my function. Maybe the mouseclick is being detected(?) Thought I’d just loop and spacebar to start a second loop (AutoCAAD style repeat command) and anykey to exit the loop.
Command is a paste paint command.
- Pick desired face for paint material.
- Pick destination. (Undo marker, paint shows up.)
- Again!
- anykey
- Exit…
