Load Families Freeze
Hi all,
Issue: I have a pyRevit script that copies and loads families from a source folder into a project. The script works fine for the copying part, but Revit completely freezes after the family loading/upgrading process is complete. The freezing happens after the script has reached the last part which is execution completed. Is it due to the family being upgraded to newer versions which takes up a lot of memory or merely forms.alert causing the freeze.
Any help would be greatly appreciated!
from pyrevit import revit, DB
from dfl_matrix.folderpathforfamilywise import main as folderpath_main
import shutil
import re
def is_backup_file(filename):
    return bool(re.search(r'\.\d{4}\.rfa$', filename))
def find_family_files(root_folder):
    family_files = []
    for root, _, files in os.walk(root_folder):
        for file in files:
            if file.endswith(".rfa") and not is_backup_file(file):
                family_files.append(os.path.relpath(os.path.join(root, file), root_folder))
    return family_files
def remove_config():
    CONFIG_FILE_NAME = "config.json"
    CONFIG_DIR = os.path.join(os.environ['APPDATA'], "pyRevit")
    CONFIG_FILE_PATH = os.path.join(CONFIG_DIR, CONFIG_FILE_NAME)
        if os.path.exists(CONFIG_FILE_PATH):
            os.remove(CONFIG_FILE_PATH)
def is_family_loaded(doc, family_name):
        collector = DB.FilteredElementCollector(doc).OfClass(DB.Family)
        for fam in collector:
            if fam.Name == family_name:
                return True
        return False
        return False
def is_subdirectory(child, parent):
        child = os.path.abspath(os.path.normpath(child))
        parent = os.path.abspath(os.path.normpath(parent))
        return parent == child or child.startswith(parent + os.sep)
        return False
class AutoUpgradeFamilyLoadOptions(DB.IFamilyLoadOptions):
    def OnFamilyFound(self, familyInUse, overwriteParameterValues):
        return True
    def OnSharedFamilyFound(self, sharedFamily, familyInUse, source, overwriteParameterValues):
        return True
def load_family_wise():
        DIRECTORY, DFLFAMILYLIBRARY_FOLDER, DFL2020_FOLDER = folderpath_main()
        SOURCE_FOLDER = DFL2020_FOLDER
        USER_FOLDER = DIRECTORY
        if not os.path.exists(SOURCE_FOLDER):
            forms.alert("The source folder does not exist: " + SOURCE_FOLDER, exitscript=True)
            return
        project_folder = forms.pick_folder(title="Select Project > Revit Families Folder")
        if not project_folder:
            forms.alert("No project folder selected. Script will exit.", exitscript=True)
            return
        if is_subdirectory(project_folder, USER_FOLDER) or \
                is_subdirectory(project_folder, DIRECTORY) or \
                os.path.abspath(project_folder) == os.path.abspath(DIRECTORY):
            forms.alert("The project folder cannot be Design for Leisure - Documents or any of its subdirectories.",
                        exitscript=True)
            return
        remove_config()
        family_files = find_family_files(SOURCE_FOLDER)
        if not family_files:
            forms.alert("No family files found in source folder.", exitscript=True)
            return
        selected_families = forms.SelectFromList.show(
            family_files,
            multiselect=True,
            title="Select Families to Copy"
        if not selected_families:
            forms.alert("No families selected. Script will exit.", exitscript=True)
            return
        if len(selected_families) > 30:
            response = forms.alert(
                "You've selected {} families, which may cause Revit to freeze. "
                "We recommend processing 30 or fewer at a time. Continue anyway?".format(len(selected_families)),
                yes=True, no=True
            if not response:
                forms.alert("Script cancelled. Please try again with fewer families.", exitscript=True)
                return
        # Copy families
        copied_families = []
        for family in selected_families:
            source_path = os.path.join(SOURCE_FOLDER, family)
            target_path = os.path.join(project_folder, os.path.basename(family))
                target_dir = os.path.dirname(target_path)
                if not os.path.exists(target_dir):
                    os.makedirs(target_dir)
                shutil.copy2(source_path, target_path)
                copied_families.append(family)
                continue
        if not copied_families:
            forms.alert("Failed to copy any families. Script will exit.", exitscript=True)
            return
        # Load families in small batches
        BATCH_SIZE = 5
        family_batches = [copied_families[i:i + BATCH_SIZE] for i in range(0, len(copied_families), BATCH_SIZE)]
        load_options = AutoUpgradeFamilyLoadOptions()
        # Track results
        loaded_families = []
        failed_families = []
        already_loaded_families = []
        # Insert this tracking code inside the family loading loop:
        # Replace the existing family loading section with:
        for family_batch in family_batches:
            with revit.Transaction("Load Family Batch"):
                for family in family_batch:
                    family_path = os.path.join(project_folder, os.path.basename(family))
                    family_name = os.path.splitext(os.path.basename(family))[0]
                        if is_family_loaded(doc, family_name):
                            already_loaded_families.append(family_name)
                            loaded_family = clr.Reference[DB.Family]()
                            success = doc.LoadFamily(family_path, load_options, loaded_family)
                            if success:
                                failed_families.append(family_name)
        # Replace the final alert with:
        result_message = ""
        if loaded_families:
            result_message += "LOADED ({}):\n".format(len(loaded_families))
            for family in loaded_families[:10]:  # Show max 10 to prevent dialog overflow
                result_message += "- {}\n".format(family)
            if len(loaded_families) > 10:
                result_message += "... and {} more\n\n".format(len(loaded_families) - 10)
                result_message += "\n"
        if failed_families:
            result_message += "FAILED ({}):\n".format(len(failed_families))
            for family in failed_families[:10]:  # Show max 10 failed
            if len(failed_families) > 10:
                result_message += "... and {} more\n\n".format(len(failed_families) - 10)
        result_message += "Already loaded: {}".format(len(already_loaded_families))
        forms.alert("Project Folder: {}\n\n{}".format(project_folder, result_message), title="Family Loading Results")
if __name__ == "__main__":
    load_family_wise()
I’ve seen issues on my side as well with upgrading families and revit freezing. Revit 2023-2025.
We have separate families built for each version, so we just had to make sure they were all the correct version. But, let me know if you come across a different solution.
Hi Martin, I have finally found a safe way to load families into Revit without freeze, here is the script below! I am using a Custom Failure Preprocessor python class which properly handles failures and warnings during family loading…. and I also dipose the transaction after each family load making the script not consuming too much memory!!! Hope this Helps,
# Safe Loading Classes
class PythonFailurePreprocessor(DB.IFailuresPreprocessor):
    Python implementation of the FailurePreprocessor
    Handles failures during family loading to prevent Revit from freezing
    def __init__(self, log_directory, log_to_file=True):
        self.log_to_file = log_to_file
        self.log_file_path = os.path.join(log_directory, "log_LoadFamilies.txt")
        self.overwrite = True  # Default to overwrite existing families
    def PreprocessFailures(self, failures_accessor):
        Process failures that occur during family loading
            failure_messages = failures_accessor.GetFailureMessages()
            if failure_messages.Count == 0:
                return DB.FailureProcessingResult.Continue
            if self.log_to_file:
                self._log_failures_to_file(failure_messages, failures_accessor)
                self._handle_failures_without_logging(failure_messages, failures_accessor)
            # Return based on overwrite setting
            if self.overwrite:
                return DB.FailureProcessingResult.ProceedWithRollBack
            add_message("**Error in PreprocessFailures**: {}".format(str(e)))
    def _log_failures_to_file(self, failure_messages, failures_accessor):
        """Log failures to file and delete warnings"""
            # Use Python file handling
            append_mode = os.path.exists(self.log_file_path)
            with open(self.log_file_path, 'a' if append_mode else 'w') as writer:
                # Write log header
                now = datetime.now()
                format_string = "%Y%m%d%H%M"
                writer.write("-----------------------------------------------------\n")
                writer.write("log: {0}\n".format(now.strftime(format_string)))
                # Process each failure message
                for failure_message in failure_messages:
                        failure_message.GetFailureDefinitionId()
                        description = failure_message.GetDescriptionText()
                        writer.write("{0}\n".format(description))
                        failures_accessor.DeleteWarning(failure_message)
                        writer.write("Error processing failure message: {0}\n".format(str(e)))
            add_message("**Error logging failures**: {}".format(str(e)))
    def _handle_failures_without_logging(self, failure_messages, failures_accessor):
        """Handle failures without logging"""
                    add_message("**Error handling failure message**: {}".format(str(e)))
            add_message("**Error handling failures**: {}".format(str(e)))
class PythonFamilyLoadOptions(DB.IFamilyLoadOptions):
    Python implementation of IFamilyLoadOptions
    Controls how families are loaded when they already exist
    def __init__(self, overwrite_parameters=True):
        self.overwrite_parameters = overwrite_parameters
    def OnFamilyFound(self, family_in_use):
        """Called when family is found in project"""
        # Return tuple: (should_load, overwrite_parameter_values)
        return (True, self.overwrite_parameters)
    def OnSharedFamilyFound(self, shared_family, family_in_use):
        """Called when shared family is found"""
        # Return tuple: (should_load, family_source, overwrite_parameter_values)
        return (True, DB.FamilySource.Project, self.overwrite_parameters)
def safe_load_family(doc, family_path, project_folder):
    Safely load a family with proper error handling and failure preprocessing
    Args:
        doc: Revit document
        family_path: Path to family file
        project_folder: Project folder for logging
    Returns:
        tuple: (success, family_name, error_message)
    family_name = os.path.splitext(os.path.basename(family_path))[0]
    # Check if family is already loaded
        return (True, family_name, "Already loaded")
    # Create transaction with proper error handling
    transaction = DB.Transaction(doc, "Loading Family: {}".format(family_name))
    # Set up failure handling
    failure_options = transaction.GetFailureHandlingOptions()
    failure_preprocessor = PythonFailurePreprocessor(project_folder, log_to_file=True)
    failure_options.SetFailuresPreprocessor(failure_preprocessor)
    transaction.SetFailureHandlingOptions(failure_options)
        transaction.Start()
        # Create family load options
        family_load_options = PythonFamilyLoadOptions(overwrite_parameters=True)
        # Attempt to load the family
        success = doc.LoadFamily(family_path, family_load_options, loaded_family)
        if success:
            transaction.Commit()
            return (True, family_name, "Loaded successfully")
            transaction.RollBack()
            return (False, family_name, "Failed to load (unknown reason)")
        return (False, family_name, "Error: {}".format(str(e)))
    finally:
        if transaction:
            transaction.Dispose()
add_message("**Script Initiated**: Load Family Wise | **Revit Version**: {}".format(
    revit.uidoc.Application.Application.VersionNumber))
