List Family Sizes Error
HI everyone, I’m trying to get a list of the Families Size, but I hasn’t been working for a while, below is the error it shows. If anyone can help me on how to solve this, I really need it for my job.
ERROR [pyrevit.revit] Error in ErrorSwallower Context. | <type ‘exceptions.Exception’>:The model could not be saved: (COleException 0x80030002)
File “C:\Users\ODP-10981 DC\AppData\Roaming\pyRevit-Master\extensions\pyRevitTools.extension\pyRevit.tab\Analysis.panel\Tools.stack\Inspect.pulldown\ListFamilySizeCreator.pushbutton\ListFamilySizeCreator_script.py”, line 113, in
Exception: The model could not be saved: (COleException 0x80030002)
Autodesk.Revit.Exceptions.FileNotFoundException: The model could not be saved: (COleException 0x80030002)
@Danycares92 ,
good question. i managed my code to get this:
import System
import time
#import ipywidgets as widgets
#from IPython.display import display
from pyrevit import script, revit, DB, forms
# pyRevit
from pyrevit import DB, UI
from pyrevit import PyRevitException, PyRevitIOError
# pyrevit module has global instance of the
# _HostAppPostableCommand and _ExecutorParams classes already created
# import and use them like below
from pyrevit import HOST_APP
from pyrevit.compat import safe_strtype
from pyrevit import framework
from pyrevit.output import linkmaker
from pyrevit.userconfig import user_config
# .NET Imports
clr.AddReference("System")
from System.IO import FileInfo
#  ╚╝ ╩ ╩╩╚═╩╩ ╩╚═╝╩═╝╚═╝╚═╝ VARIABLES
app = __revit__.Application
mb = 1048576.0
kb = 1024.0
# get Schedules
def getSize(p, mb=mb, kb=kb, kbOnly = False):
	sb = FileInfo(p).Length
	if sb < mb or kbOnly:
		return '%.3f KB' % (sb / kb)
		return '%.3f MB' % (sb / mb)
time_start = time.time()
directory = 'C:/Users/andre/Desktop/Familien'
names = os.listdir(directory)
familyFileNames = [i for i in os.listdir(directory) if i.endswith(".rfa")]
familyPaths = [os.path.join(directory,i) for i in familyFileNames]
stats = [os.stat(i) for i in familyPaths]
sizes = [i.st_size for i in stats]
converted = [int(i) for i in sizes]
kiloBite = [(str(i/1000) + " KB") for i in converted]
OUT = zip(names,kiloBite) #converted)
for p in OUT:
	print(p)
KR
Andreas
Hi Andreas, Thanks for your answer.
I don’t have any coding knowledge, so if you can please describe what should I do with this, It would be great.
Thanks again, and sorry for my lack of knowledge.
KR,
Daniela
@Danycares92 ,
where to start :wink: ?
mb = 1048576.0
kb = 1024.0
# get Schedules
for p in OUT:
	print(p)
the main part happens in this area… you can paste to chatGPT and ask “please write comments to this code, what it does, do not change the code!”
i can just recomment you do a basic course in Python ( you get by 10€, online with a punch of content). Or learn here www.learnrevitAPI.com. I have only Dynamo background.
…programming is not so hard as it sounds.
KR
Andreas
@Danycares92 welcome,
taken directly from the Revit API docs
The given file, path or network location could not be found during save.
It means that the temp file save location is inaccessible or that the original family is not accessible.
you could encapsulate the line 113 of the script in a try:except: so that it can bypass the specific families not working.
  1. Open:
  2. @ line 113
                        fam_doc.SaveAs(fam_path, save_as_options)
                        print("Family cannot be saved in this location: {}".format(fam_path))
  1. report with a screen capture the output windows with the results. If conclusive, I will commit this change.
