Latest revision number on sheet
Hello :slight_smile:
Is there a way to get the latest revision of the drawing?
For example, if I have a list of revisions like [P01, P02, T01, C01, C02], how can I get the C02 string value?
At the moment, I am unable to see a solution :cry: I really want to avoid iterating over each drawing and getting the list of revision sequences, and then getting the sequential number with the prefix.
@Gian_Claudio ,
i think you have index by -1.
so you have the last item
lis = ["A1","A2","A3","A4","A5"]
print(lis)
lastItem = lis[-1]
print(lastItem)
grafik
hello :slight_smile:
sorry I have not given more context
sheetInDoc = query.get_sheets()
rev=[]
for i in sheetInDoc:
    if query.get_current_sheet_revision(i) != None:
        latest =[query.get_current_sheet_revision(i)][0]
        rev.append([i.SheetNumber, latest,\
            latest.RevisionDate,\
            latest.Description,\
            latest.RevisionNumberingSequenceId
print (rev)
from here how can I get the latest revision?
@Gian_Claudio
query is from which module ?
the model is from pyrevit:
and I have imported like that :slight_smile:
from pyrevit.revit import query
@Gian_Claudio
what do want to access ?
@Gian_Claudio
accessing by Number ?
you want the index!
yes, I want to get the index… I am not sure how to get this it looks like that I need to iterate over and get the index of each numbering type
@Gian_Claudio
tricky, i just can access the template but not the index itself
2024-06-05_17h24_24
2024-06-05_17h24_33
rev = []
        latest = [query.get_current_sheet_revision(i)][0]
        # rev.append([i.SheetNumber, latest,latest.RevisionDate,latest.Description,latest.RevisionNumberingSequenceId])
        rev.append(latest.RevisionNumberingSequenceId)
print(doc.GetElement(rev[0]).Name)
accessing the sequense
Assuming that the “latest” revision means the more recent one, you can just check wich element of the list has the max value at index 2:
latest_rev = max(rev, key=lambda x: x[2])
The key argument is used to extract the values to compare, and it defaults to identity (= the value itself);
The lambda lets you create an anonymous function on a single line.
Taking a step further, I would take advantage of generators and functional programming to skip the list
sheets_and_revs = (
    (s.SheetNumber, query.get_current_sheet_revision(s))
    for s in query.get_sheets()
sheets_with_revs = (sr for sr in sheets_and_revs if sr is not None)
latest = max(sheets_with_revs, key=lambda x: x[1].RevisionDate)
sheet_number, revision = latest
I don’t know if this is what you mean, but I hope it can help.
def GetRevisionSequences(sheets):
    revisionSequences = []
    for sheet in sheets:
        sub_lst = []
        revision_Ids = sheet.GetAllRevisionIds()
        # print (revisions)
        for Id in revision_Ids:
            sub_lst.append(doc.GetElement(Id).SequenceNumber)
        revisionSequences.append(sub_lst)
    return revisionSequences
def GetAllRevisionsOnSheet(sheets):
    revisions = []
        sub_lst = []
            sub_lst.append(doc.GetElement(Id))
        revisions.append(sub_lst)
    return revisions
selectedSheets = forms.select_sheets()
allRevisions = GetAllRevisionsOnSheet(selectedSheets)
revisionSequences = GetRevisionSequences(selectedSheets)
latestIndex = [len(revList)-1 for revList in revisionSequences]
latestRevision = []
for sublst,ind in zip(allRevisions,latestIndex):
    latestRevision.append(sublst[ind])
print ("All revision sequences on sheets: ")
print (revisionSequences)
print ("---------------------------------------------------------------------")
print ("The latest index: ")
print (latestIndex)
print ("The latest revision: ")
print (latestRevision)
