Starting the Manage Keynotes app I select the option Select a different keynote file and select one of default Revit keynote files. Then I get this error message:
Any suggestion would be appreciated.
Thank you.
Thank you.
hi @EvgenyK
AFAIK the default revit keynotes files are read only
This may lead to error while using the keynote manager
I tried it myself, loading one of the default keynote file I got errors,
Copying it somewhere else and and removing the read only flag, it worked as expected.
Could be a problem with the file content? Do you have a file which is proven to be working for the Keynotes app?
this one for example, I already remove the read only tag
Thank you for sharing the file. Unfortunately the app gives the same error message. ![]()
The keynote manager code has not change much in ages.
You could try create a new empty file then use the KM in it
Or
Uninstall and install latest pyrevit again.
Hi Jean-Mark.
Thank you for your suggestion. I have a brand-new computer for a month or so, and the pyRevit installation is fresh.
You are right, the problem is not in the Keynotes app, but in the pyRevit core. I will try to find a solution somewhere else.
Best Regards,
Evgeny.
A solution was found. Just use the Convert option on opening the keynotes file.
Anyways thank you for your help.
