Hi all,
I am running a tool through the CLI. One of the 120 files has a custom calculator loaded that is not on my computer. The file was generated outside my office. I have added a suppressor to the Open Project dialog box in the back of the attached image and that works. The problem is that when I run the script through the CLI it somehow causes the Journal file to error. Has anyone run into something like this before?
If I select “Enter interactive mode” the script continues and finishes as expected but Revit does not close as the Journal file has broken.
