I’m trying to implement an IUpdater in my pyRevit extension. I followed Erik Frits’s tutorial - How to Create IUpdater in Revit with pyRevit (Create Custom Features)
The tutorial works well for detecting modified elements, but I’m having trouble detecting added and deleted elements.
In my test, the updater is successfully triggered when I modify a wall. I can see that:
GetModifiedElementIds()returns the modified wall ID. -
The message
Modified: 1is printed. -
A custom parameter (
TEST) is successfully updated to"ModifiedElement".
However, when I:
create a new wall, or
delete an existing wall,
the updater does not appear to detect those actions. GetAddedElementIds() and GetDeletedElementIds() are always empty.
For testing, I’m using the following code:
BuiltInCategory,
ElementId
sender = __eventsender__
args = __eventargs__
doc = args.GetDocument()
modified_el_ids = args.GetModifiedElementIds()
deleted_el_ids = args.GetDeletedElementIds()
new_el_ids = args.GetAddedElementIds()
print("Added: {}".format(len(new_el_ids)))
print("Modified: {}".format(len(modified_el_ids)))
print("Deleted: {}".format(len(deleted_el_ids)))
for el_id in modified_el_ids:
el = doc.GetElement(el_id)
if el.Category and el.Category.Id == ElementId(BuiltInCategory.OST_Walls):
print("Modified element: {} / {}".format(el.Id, el.Name))
el.LookupParameter("TEST").Set("ModifiedElement")
for el_id in new_el_ids:
print("New element: {} / {}".format(el.Id, el.Name))
el.LookupParameter("TEST").Set("NewElement")
My question is:
Is there anything special that must be done when registering an IUpdater to receive notifications for newly created or deleted elements?
Or is there a limitation in pyRevit’s doc-updater.py implementation that prevents GetAddedElementIds() and GetDeletedElementIds() from being populated?
Any suggestions would be greatly appreciated.
Thanks!
