Issue with pyRevit 6.1.0 when running scripts from a shared drive
Hi all,
After updating to pyRevit 6.1.0, I started experiencing issues with my scripts.
Setup
  • My scripts are stored on a shared network drive so they can be deployed to colleagues.
  • The scripts import functions from several custom libraries, which are also located on that same shared drive.
Problem
When running a script for the first time, everything works perfectly.
However, after:
  • switching views, or
  • running another script
the scripts stop executing entirely. They simply do nothing anymore.
Troubleshooting
  • Running the exact same scripts from my local drive works fine.
  • Downgrading to pyRevit 5.3.1 also resolves the issue — everything works as expected again.
  • I attempted some debugging to identify where the scripts stop executing, but I couldn’t find anything unusual.
Any insights would be greatly appreciated.
Thanks!
In the option set the logging to verbose and take. A look at the logs and report here.
Or open an issue on GitHub, but end of the day, we will still need the logs
