Issue with opening pyRevit in Revit 2026/5, etc - Failed to initialize the add-in "PyRevitLoader"
We deploy pyRevit CLI to about 90 client machines. We have one client machine which has an issue with the pyRevit plugin in Revit, it won’t load with the following error message:
We ran the full uninstall of pyRevit, rebooted, installed the pyRevit CLI but to no avail, the issue persists. The file in the error is also not present on the sytem. Below is the output of the pyrevit.exe env and pyrevit.exe revits --installed commands, could you please let us know what is the cause of this issue and how to fix it:
C:\Program Files\pyRevit CLI>pyrevit.exe clones
master | Branch: "master" | Version: "7.0.0.26278+2233
" | Path: "C:\pyRevit"
C:\Program Files\pyRevit CLI>pyrevit.exe revits --installed
==> Installed Revits
Autodesk Revit 2027 | Version: 27.2.0.39 | Build: 20260716_1515(x64) | Language: 1033 | Path: "C:\Program Files\Autodesk\Revit 2027\"
2026 First Customer Ship | Version: 26.0.4.409 | Build: 20250227_1515(x64) | Language: 1033 | Path: "C:\Program Files\Autodesk\Revit 2026\"
2025 First Customer Ship | Version: 25.0.2.419 | Build: 20240307_1300(x64) | Language: 1033 | Path: "C:\Program Files\Autodesk\Revit 2025\"
Autodesk Revit 2024 | Version: 24.3.50.51 | Build: 20260518_1515(x64) | Language: 1033 | Path: "C:\Program Files\Autodesk\Revit 2024\"
2023.1.8 | Version: 23.1.80.30 | Build: 20250724_1515(x64) | Language: 1033 | Path: "C:\Program Files\Autodesk\Revit 2023\"
2022.1.5 | Version: 22.1.50.17 | Build: 20230915_1530(x64) | Language: 1033 | Path: "C:\Program Files\Autodesk\Revit 2022\"
C:\Program Files\pyRevit CLI>pyrevit.exe env
==> Attachments
master | Product: "Autodesk Revit 2027" | Engine: DEFAULT (2712) | Path: "C:\pyRevit" | AllUsers
master | Product: "2026 First Customer Ship" | Engine: DEFAULT (2712) | Path: "C:\pyRevit" | AllUsers
master | Product: "2025 First Customer Ship" | Engine: DEFAULT (2712) | Path: "C:\pyRevit" | AllUsers
master | Product: "Autodesk Revit 2024" | Engine: DEFAULT (2712) | Path: "C:\pyRevit" | AllUsers
master | Product: "2023.1.8" | Engine: DEFAULT (2712) | Path: "C:\pyRevit" | AllUsers
master | Product: "2022.1.5" | Engine: DEFAULT (2712) | Path: "C:\pyRevit" | AllUsers
==> Installed Extensions
pyApex | Type: UIExtension | Repo: "https://github.com/apex-project/pyApex.git" | Installed: "C:\pyRevit\master\Extensions\pyApex.extension"
pyChilizer | Type: UIExtension | Repo: "https://github.com/dnenov/pyChilizer" | Installed: "C:\pyRevit\master\Extensions\pyChilizer.extension"
C:\Users\nbrooks\AppData\Roaming\pyRevit\Extensions
==> Extension Search Paths
==> Running Revit Instances
==> User Environment
Microsoft Windows 10 [Version 10.0.26200]
Executing User: PHILADELPHIA\nbrooks
Active User: PHILADELPHIA\nbrooks
Admin Access: No
%APPDATA%: "C:\Users\nbrooks\AppData\Roaming"
Latest Installed .Net Framework: 10.0.14
No .Net-Core Target Packs are installed.
pyRevit CLI v5.3.1.25308+1659.87ab3dfd505f7f8ddfb7375b52a1ea7645640f7a
This is the key insight: pyRevit stopped shipping binaries around 6.3. Therefore a newer CLI is needed.
OK, so I need to download a newer version of the CLI and install it? Thanks, I am not a pyRevit user or developer, I am a sysadmin that helps this client deploy applications.
Yes you do need the latest pyrevit CLI
